injector question
Old Oct 13, 2007 | 03:22 PM
4doorekITR's Avatar
Default injector question
i got a set of stock 310cc injectors from a 2000 audi a4 1.8t. My question is ,,the plugs look the same as on my 2000 ITR ..can i run these injectors or do they need a resistor box?
Old Oct 13, 2007 | 04:21 PM
doood's Avatar
been there done that
Default Re: injector question (4doorekITR)
why do you want bigger injectors in the first place?
Old Oct 14, 2007 | 02:59 AM
4doorekITR's Avatar
im building the motor..upgraded valvetrain,flat faced valves.skunk 2 stage 2 cams.2 mm headgasket.Eventually this winter im gonna build the bottom end with CTR pistons to get the compresion up alittle higher so i can run a bigger cam..Im figuring ill probly need larger injectors wont i?..You think im just gonna put 310cc injectors on a stock motor? what good would that do?
Old Oct 14, 2007 | 05:15 AM
Dogginator's Avatar
Daisy... Daisy...
Measure the resistance with a volt meter. They should be in the 10-15 Ohm range. If they are lower, you need a resistor box to protect the ECU.
Old Oct 14, 2007 | 06:37 PM
4doorekITR's Avatar
Default Re: injector question (Dogginator)
cool,im gonna go do that right now.I just got picked up a new voltmeter last week.Thanks for the advice man really.Most people on here just reply with smart *** **** thats no help at all.
Old Oct 14, 2007 | 06:48 PM
4doorekITR's Avatar
i just tested the resistance.they read 15 ohms on the dot
Old Oct 15, 2007 | 03:42 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (4doorekITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4doorekITR &raquo;</TD></TR><TR><TD CLASS="quote">i just tested the resistance.they read 15 ohms on the dot</TD></TR></TABLE>
You are good to go.
WHEELS845
May 26, 2010 11:34 AM
2000siturboR
Oct 7, 2008 09:27 AM
swt_666
May 16, 2007 09:33 PM
spockeg
Oct 6, 2006 09:49 PM
Sassafrass
Oct 9, 2004 09:58 PM
