Timing belt problem
Old Oct 13, 2007 | 11:18 AM
SilvrBullet GSR's Avatar
Default Timing belt problem
if my timing belt is lose could it be that its worn or that my timing could be off.When the engine is off only one part of the belt seems to be lose. I dont think it makes any weird noise that i should be worried about, no sqeaks no knocking although it kinda backfires when i shift from second to third about 3500 4000 rpm's. i recently put some stp fuel injector cleaner but i havent really been able to push the car but it drive fine. well this will probably help its a b18c1 with a b16 head. no mods just a cold air intake..
Old Oct 13, 2007 | 12:56 PM
doood's Avatar
been there done that
Default Re: Timing belt problem (SilvrBullet GSR)
check the tensioner. might be a good time to replace that, the belt, and water pump if you havent recently.
Old Oct 13, 2007 | 01:06 PM
Default Re: Timing belt problem (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">check the tensioner. might be a good time to replace that, the belt, and water pump if you havent recently.</TD></TR></TABLE>
yea i had my car in the shop and the mechanic told me if i was going to replace the belt, might as well change the water pump and the tensioner. plus i think i need to replace my valve cover gasket. does it robb your performance if your timing belt is loose?
Old Oct 13, 2007 | 01:15 PM
doood's Avatar
uhh, yes. it can skip a tooth and bend some valves.
faSHOwidIT
Feb 25, 2006 03:00 AM
kaoss_11
Aug 9, 2005 01:55 PM
Iomega01
Aug 2, 2005 08:12 PM
RedRyda
Jul 28, 2004 06:20 PM
xstalkrx
Jun 29, 2004 08:03 PM
