distributor oil leak
Old Oct 13, 2007 | 06:51 AM
LSej1's Avatar
Default distributor oil leak
My EJ1 is a LS swap in it. When i got the car the guy said the 'o' ring on the distributor shaft was shot so it leaks a little bit of oil. It doesnt leak much - maybe a quart every few months or so. Has anyone ever heard of this or do you think it would be the distributor cap gasket?
Old Oct 13, 2007 | 08:34 AM
Baggy Spandex's Avatar
Default Re: distributor oil leak (LSej1)
#7 in the diagram. Part Number : 30110-PA1-732
Should only cost about a buck or two. Very simple to install.
Old Oct 13, 2007 | 08:42 AM
B16B_coupe's Avatar
HRD PKR
plus:when you install it dont use a screwdriver, it will go on with your hands
put some oil on the o-ring so it dont get damaged at install.
Old Apr 22, 2008 | 12:49 PM
team_sol06's Avatar
i had the same problem
Old Apr 22, 2008 | 12:50 PM
team_sol06's Avatar
were did u buy the o ring
Old Apr 22, 2008 | 12:56 PM
blk92_d16's Avatar
I had one come in my full gasket kit. Easy to install once lubed and you can find them at the dealership of course.
Old Apr 22, 2008 | 06:47 PM
HeikDiesel's Avatar
Default Re: (blk92_d16)
Use a flat blade screwdriver and index the distributor to the engine by making a scratch mark straight across the top so you know how to index the distributor. Remove 3 bolts, remove the plug wires and keep track of what goes where, and wiggle it off. Remove the old o-ring, install the new one, use some grease or oil to lubricate the o-ring. Make sure the tangs on the distributor match the camshaft. Install it and index it. Tighten the 3 bolts, install the plug wires, and you are good to go
Old Apr 22, 2008 | 06:52 PM
z6hatchboy's Avatar
Default Re: (team_sol06)
You local honda dealership should have them, the one nearest me said they always try to have a few laying around, its only a few bucks.
cast.aluminum
Dec 15, 2014 10:53 AM
ribal_gh
11
Oct 31, 2012 07:49 AM
DevLishPlaya
12
Jul 25, 2007 11:05 AM
sonson6
Mar 20, 2007 07:56 PM
