so my Z6 distributor is leaking oil :(
like so
i did a search and read that theres a oil seal inside that can be replaced. is this hard to do? and where can i get the seal? i checked (hondaautomotive) and i cant thell which one is the seal.
help!
thx
edit:
oil in distributor
Modified by DevLishPlaya at 4:38 PM 7/25/2007
Stouts 'n' Scotch
Re: so my Z6 distributor is leaking oil :( (DevLishPlaya)
Distributor o-ring. All you have to do is remove the distributor and fish out the o-ring on the shaft. Very easy.
http://www.hondaautomotivepart...EC%29
#6 in that picture.
#6 in that picture.
Its the Distributor O-ring...very easy to install. Just go to your local honda dealership and pick one up, its like a couple bucks...not worth the time of ordering it. Plus, there wont be any confusion, just ask for it.
Re: (1995Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">Distributor o-ring. All you have to do is remove the distributor and fish out the o-ring on the shaft. Very easy.
#6 in that picture.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Civic »</TD></TR><TR><TD CLASS="quote">Its the Distributor O-ring...very easy to install. Just go to your local honda dealership and pick one up, its like a couple bucks...not worth the time of ordering it. Plus, there wont be any confusion, just ask for it.</TD></TR></TABLE>
thanks for your replys.
CRAP!!! i forgot to mention! nope its not the O-ring cause i have a new one in there. I have oil IN the distributor
Re: (DevLishPlaya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DevLishPlaya »</TD></TR><TR><TD CLASS="quote">
If you have oil in the the distributor, are you sure its not from when you WERE leaking oil but just didnt clean it out?
If anything else, you have a bad valve cover gasket or cam seal.
Re: (1995Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Civic »</TD></TR><TR><TD CLASS="quote">If you have oil in the the distributor, are you sure its not from when you WERE leaking oil but just didnt clean it out?
If anything else, you have a bad valve cover gasket or cam seal.</TD></TR></TABLE>
valve cover gasket and the cam seal are ok... i traced the leak and its comming from the distributor itself...
if the O-ring is bad, is that the only way that the oil would end up inside the disdtributor?
Re: (DevLishPlaya)
if the O-ring is bad, is that the only way that the oil would end up inside the disdtributor?</TD></TR></TABLE>
No it wouldnt be the only way.
Like i said, it could also be caused from a bad valve cover gasket or cam seal. Are you seeing a steady leak, or is it just oil that remained IN the dizzy from when the O-ring was bad?
Re: (1995Civic)
If its inside the distributor then the distributor oil seal is bad. They are like 5 bucks on line plush shipping. Just google distributor oil seal to find one shop around a little I saw them anywhere from $5 to $15 when I ordered mine. If you need help I think I still have step by step instructions with some pics I can email you just let me know
Edit: the O ring only seals the distributor housing and the head from leaking. If he has oil inside the distributor than the distributor oil seal is bad.
Re: (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 »</TD></TR><TR><TD CLASS="quote">If its inside the distributor then the Distributor oil seal is bad. They are like 5 bucks on line plush shipping. Just google distributor oil seal to find one shop around a little I saw them anywhere from $5 to $15 when I ordered mine. If you need help I think I still have step by step instructions with some pics I can email you just let me know</TD></TR></TABLE>
Ahh damn, completely forgot about that ******! lol
Good call.
Good call.
Re: (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 »</TD></TR><TR><TD CLASS="quote">If its inside the distributor then the distributor oil seal is bad. They are like 5 bucks on line plush shipping. Just google distributor oil seal to find one shop around a little I saw them anywhere from $5 to $15 when I ordered mine. If you need help I think I still have step by step instructions with some pics I can email you just let me know
Edit: the O ring only seals the distributor housing and the head from leaking. If he has oil inside the distributor than the distributor oil seal is bad.</TD></TR></TABLE>
yes! can you please email me step by step and the pics!
TIA.
TIA.
Re: (DevLishPlaya)
Yeah, blah, I was gonna say, "why is everybody saying o-ring when it's INSIDE the dizzy???"
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
Lmao...because im retarded
