oil pan help
Old Oct 12, 2007 | 05:54 PM
shadohconspiracy's Avatar
Default oil pan help
ok so i changed the oil on this car for the first time today. and when i was putting the drain plug on , it just kept on screwing in which means the threads are stripped. there wasnt any other option so i just tried my best and put it on the tightest. now my car is like drippin hella oil. when i poured the oil back in i got it like almost near the full mark on the dipstick. after like 1 1/2 hour im already below the low mark on the dipstick.
what are some ways i can solve this ? where can i take it to have it rethreaded with a bigger size bolt? around how much is this going to cost me? thank you
Old Oct 12, 2007 | 08:54 PM
bump?
Old Oct 12, 2007 | 08:59 PM
akunamatta's Avatar
* B A N N E D *
you can get an oversized plug like you said... but that is just a temporary fix i would only reccomend using it once, it can also make metal shavings in your oil pan when you torque it down.
btw whats with these advertissments in the op? they are lame imo this site is falling apart.
Old Oct 12, 2007 | 09:19 PM
i heard you can pick up some oversized self tapping plugs at autozone. anyone use them before?
Old Oct 12, 2007 | 09:35 PM
akunamatta's Avatar
* B A N N E D *
i have one in my pan right now, just make sure you torque it down straight so it seals right, but i havent yet changed my oil since, im planning on replacing the pan.
Old Oct 12, 2007 | 09:50 PM
alright another question, is rubber seals or metal seals better?
Old Oct 12, 2007 | 09:54 PM
hmtcrxsir's Avatar
Default Re: (shadohconspiracy)
since you planning to take the oil pan out anways to get it rethreaded. why not just replace the whole oil pan and make sure next time youll be careful not to strip the thread from over tightening it. save yourself the headache and worries.
Old Oct 12, 2007 | 10:17 PM
im planning to do this without taking out the oil pan.... and i did not strip it myself. it was from the previous owner and this is my first time doing an oil change and i came to realize this issue.
Old Oct 12, 2007 | 10:19 PM
hmtcrxsir's Avatar
not a good idea because you may have metal shaving in the oil pan. do it right
Old Oct 12, 2007 | 10:23 PM
ill leave some oil in there before i do it , so the shavings can come out with the oil . or i can just pour some fresh oil in to run the shavings down with it out of the drain hole.
Old Oct 12, 2007 | 10:26 PM
hmtcrxsir's Avatar
dont take a chance
Old Oct 12, 2007 | 10:44 PM
Default Re: (akunamatta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akunamatta &raquo;</TD></TR><TR><TD CLASS="quote">i have one in my pan right now, just make sure you torque it down straight so it seals right, but i havent yet changed my oil since, im planning on replacing the pan.</TD></TR></TABLE>
did you take off your pan to do yours?
Old Oct 13, 2007 | 09:07 AM
akunamatta's Avatar
* B A N N E D *
no, but once i threaded it down all the way i took it out and ran fresh oil through, but just get a new pan seriously.
Old Oct 13, 2007 | 09:10 AM
EkLanta's Avatar
tell who ever sold you the oil pan you screwed me over. i want a new one!
Old Oct 13, 2007 | 10:14 AM
Syndacate's Avatar
Default Re: (EkLanta)
Re-Tap the hole, you can rent taps at most auto parts stores (- Archidictus).
Run a tap through the hole, get a new drain plug, and enjoy no leaky oil .
Old Oct 13, 2007 | 02:08 PM
i just bought a over sized self tapping plug and installed it... and its not leaking at all. i left a little oil in before i put the plug in and once i tapped it i pulled it back out and let the flakes run down with the oil and i ran some fresh oil thru it too. should be okay for awhile
whytetygerwolf
18
May 27, 2014 05:56 PM
jdmda_1.7a
Feb 15, 2011 07:35 AM
z4nd
Honda Civic (2001 - 2005)
27
Oct 2, 2010 09:39 PM
CRXified
18
Oct 31, 2006 04:58 PM
92preludeSI
Mar 10, 2003 07:33 PM
