Vtec Soleniod Miswiring?
Old Oct 12, 2007 | 02:20 PM
slacks's Avatar
Default Vtec Soleniod Miswiring?
when checking my vtec solenoid it became apparent that the green plug was plugged in....and the other one (sorry i forget the names :/) was non-existent
no other wires were found that could plug into this except for one that seemed to be yellow/greenish/blue? wrapped up and about 3 inches too car to plug in.
anyone able to help me wire this or find my missing connector?
Old Oct 12, 2007 | 02:33 PM
slacks's Avatar
Default Re: Vtec Soleniod Miswiring? (slacks)
halp?
Old Oct 12, 2007 | 03:05 PM
slacks's Avatar
any help?
Old Oct 12, 2007 | 04:09 PM
92hatchboi's Avatar
well ur vtec solenoid is unplug and the vtec pressure switch is plugged in. try and locate the plug for the solenoid. what car is the motor in?
Old Oct 12, 2007 | 04:51 PM
slacks's Avatar
Default Re: Vtec Soleniod Miswiring? (92hatchboi)
d16z6 in a 94 civic coupe
Old Oct 12, 2007 | 06:17 PM
slacks's Avatar
moar bump?
Old Oct 12, 2007 | 06:22 PM
Jdmglenn's Avatar
Is your coupe an EX model? if not youre gonna have to hardwire the Vtec solenoid (the extra grey single wire plug) straight to the ecu
Old Oct 12, 2007 | 06:39 PM
slacks's Avatar
Default Re: Vtec Soleniod Miswiring? (Jdmglenn)
originally it was a DX but the last owner had a d16z6 put in so i don't think it has the connector for it
and is it just one wire that goes to the ecu? or do i need a ground as well?
Old Oct 12, 2007 | 06:49 PM
Jdmglenn's Avatar
The Vtec solenoid (top one with just one wire) has one wire that goes to the ecu.
The Vtec Oil pressure sensor bottem one (has the light green plastic) has a signal and a ground wire.
Look at your ecu plugs to see if there are wires in these locations
A4-VTS VTEC solenoid
D6-VTM VTEC pressure switch
Old Oct 12, 2007 | 07:16 PM
slacks's Avatar
awesome! i'll fix that up asap
thanks JdmGlenn
leroyb
Apr 13, 2007 03:15 PM
GdmLaz
Dec 25, 2004 08:47 AM
Doug684
Jun 12, 2004 07:20 PM
