Highbeams will not shut off...
Old Oct 12, 2007 | 10:50 AM
show_time's Avatar
Default Highbeams will not shut off...
i recently purchased a 1990 honda accord, it's not in the best shape, but im just trying to get some experience with fixing things myself, neways, i wus messin around with the highbeams..i turned the highbeams on and off a few times..and on the last time the whole dashboard (speedometer, rev metre, etc.) turned off and the highbeams stayed on, my normal lights will not come back on...i have absolutely no clue what happened. Please help, thnx.
Salah
Old Oct 12, 2007 | 01:43 PM
Honda_Accord's Avatar
Default Re: Highbeams will not shut off... (show_time)
check all fuses under hood and under ur dash board on driver side.
Old Oct 12, 2007 | 01:53 PM
drunkmunky's Avatar
normally the issues don't pertain to the fuses under the dashboard, where as the problems typically occur in the fusebox under the hood. You may have to go to a mechanic or dealership to get some fuses replaced, or if the connections are loose, get them re soldered.
Old Oct 12, 2007 | 02:21 PM
radiuslight's Avatar
might be fuses and relays
Old Oct 12, 2007 | 07:51 PM
Default Re: Highbeams will not shut off... (Honda_Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunkmunky &raquo;</TD></TR><TR><TD CLASS="quote">normally the issues don't pertain to the fuses under the dashboard, where as the problems typically occur in the fusebox under the hood. You may have to go to a mechanic or dealership to get some fuses replaced, or if the connections are loose, get them re soldered.</TD></TR></TABLE>
i highly doubt changing a fuse under the hood would require a mechanic or a dealership.
Old Oct 12, 2007 | 08:22 PM
drunkmunky's Avatar
What happened on my buddies car previously was that he had some relays and fuses that were completely shot. He wasn't very familiar with electrical systems so he brought it into a dealership. Personally, I don't have much experience with fuses and relays either, I find that trouble shooting those types of systems is a much more delicate process.
Old Oct 13, 2007 | 02:16 PM
show_time's Avatar
hey thnx for the help fellas, i changed the fuse in the engine fuse box and everythins back to normal, but i've been havin trouble with the fuse slot for "Day Light", everytime i instert a fuse it burns out, and i think this has been happenin ever since a few bare wires attached to the deck touched and caused a circuit shortage somewhere, but im not very sure. So my question is; what is the "Day Light" fuse for and does it have nethin to do with the stereo deck???
Old Oct 13, 2007 | 04:38 PM
jravensc's Avatar
Default Re: (show_time)
I could be wrong, but I think the Day Light is for daytime running lights. I don't know if they were that common in 1990? Was there a fuse/relay in there to begin with? Most under hood fuse boxes are the same for all models of the car for that year. If your car didn't come with running lights, the opening would still be there, but it would be empty. I cant really imagine it is tied into the radio.
Old Oct 15, 2007 | 09:34 AM
show_time's Avatar
it's in the fusebox under the dash, drivers side, and yeah there was a fuse there originally, i should probably take it into a mechanic now eh, it doesn't seem like im gonna be able to fix this problem on my own.
bugenz
Aug 22, 2015 04:31 AM
94jdmeg
Honda Civic (2006 - 2015)
Apr 16, 2008 04:38 PM
pLaTiNumSR20
Mar 6, 2008 03:22 PM
crj_lll
16
Jan 24, 2006 04:14 PM
Edwardo911
17
Sep 16, 2004 05:40 AM
