need help 96 integra***HELP***
i juss got an oil change maybe 5 days ago and it seems like its out of oil for sum reasson im thinkin its from my exhaust its striaght all the way n no muffler no cat or resin.......can that be the reason cuz it smells funny with no cat and back fires alot too without muffler
a straight-through exhaust will have nothing to do with how much oil your car burns...
- how much oil did you put in in the first place?
- how much oil is showing on the dipstick?
- look for puddles where you park your car to see if the oil is just dripping out
- check to make sure the oil filter is screwed on tight enough, same with the oil drain bolt
- just look all around the engine bay for oil leaks
- look at the your exhaust (not the pipes, the stuff that comes out), if it has a very slight blue-ish tint to it, you're burning oil
and I agree with Dogginator, do a compression test and see what your numbers are like
no leaks ne where put 4 quarts n its low now the oil light flashes..... when i smash on the car to the fullest black smoke comes out of the exhaust and when i leave it in high rpm close to redline
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwamp2006 »</TD></TR><TR><TD CLASS="quote">Valve seals....... deffininetly valve seals</TD></TR></TABLE>
Bad valve stem seals will produce white smoke under load, not black smoke. Black smoke means it's burning fuel, not oil. Burning oil produces a thick white smoke.
I would recommend doing a simple compression check on all cylinders and comparing them across the board.
rayzian
16
Aug 17, 2007 06:48 AM
mickey513
Feb 14, 2003 08:46 PM
