Rear LCA's
Old Oct 11, 2007 | 10:13 PM
EJ1chevelle's Avatar
Default Rear LCA's
hey guys im getting into doing all my suspension and recently bought omni power full adjustable coils and want to get rear lca's to go with them. i know which ones i want but i have noticed many people have a block between them with a sway bar outside everything. what its that center block between the LCA's called? i think its called a rear lower arm bar but im not sure.
thanks
im talking about the metal bar in the middle that the LCA's attach to if this helps clarify.
Modified by 93egB16A at 11:36 PM 10/11/2007
Old Oct 11, 2007 | 10:37 PM
Default Re: Rear LCA's (93egB16A)
bump...new pic
Old Oct 11, 2007 | 10:57 PM
doood's Avatar
been there done that
that's the ASR subframe brace. pretty much mandatory with a rear sway 22mm+ unless you want subframe tearout. other options, but less blingy, are bsq or beaks kits.
Old Oct 11, 2007 | 11:02 PM
bacardiboi's Avatar
if ur refering to the "metal block" that the sway bar attatches to in the pic above me, its called a subframe reinforcment kit. eg/ek chassisesises are weaksuce and need help holding onto ur bar. <-- simple explaination.
other misc ull need- these should come with the swaybar
endlink kit. its complex bolts to hold down each end of the sway bar (go in the holes in ur pretty new LCA's)
d brackets and bushings- d-shaped brackets(right next to the muffler in the pic) anf the d shaped bushings that fit into them.
Old Oct 11, 2007 | 11:10 PM
Default Re: Rear LCA's (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">that's the ASR subframe brace. pretty much mandatory with a rear sway 22mm+ unless you want subframe tearout. other options, but less blingy, are bsq or beaks kits.</TD></TR></TABLE>
ok.... so i have to buy that separately from the sway bar and LCA's then correct??
Old Oct 11, 2007 | 11:28 PM
doood's Avatar
or you can get the package deal from http://www.weaksauceparts.com or http://www.kingmotorsports.com
Old Oct 11, 2007 | 11:30 PM
ok dooood thanks for clarifying.
Old Oct 11, 2007 | 11:58 PM
Chyno's Avatar
what kind of exhaust is that looks nice!
Old Oct 12, 2007 | 01:31 AM
fullraceacura's Avatar
Default Re: Rear LCA's (Chyno)
it looks like a apexi world sport or similar
auto addict
Jul 6, 2008 12:47 PM
triple
May 23, 2006 03:45 AM
Cuong-nutz
Suspension & Brakes
Aug 8, 2005 03:45 PM
RICHJ
Dec 18, 2002 01:49 AM
mr2td
Oct 14, 2002 06:00 PM
