EK bulb type
Old Oct 11, 2007 | 10:07 PM
Andyroo's Avatar
Default EK bulb type
searched and could not find.
I have JDM SIR 96-98 headlights and what bulb type do these use?
Old Oct 11, 2007 | 10:10 PM
LwdJdmR's Avatar
Default Re: EK bulb type (Andyroo)
i believe its H1
Old Oct 11, 2007 | 10:16 PM
Andyroo's Avatar
Default Re: EK bulb type (LwdJdmR)
i beleive not
Old Oct 11, 2007 | 10:56 PM
NOFX's Avatar
H-T White Ops
The same as any other 6th gen headlight.
H4 aka 9003.
Old Oct 12, 2007 | 09:23 AM
Andyroo's Avatar
well, how come some ppl talk about h4h??? some sort of jdm bulb type? is this what EK jdm headlights use or no?
Old Oct 12, 2007 | 09:25 AM
lillthingz's Avatar
The bulb type is the same as the stock ones.
Old Oct 12, 2007 | 09:39 AM
NOFX's Avatar
H-T White Ops
Default Re: (Andyroo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andyroo &raquo;</TD></TR><TR><TD CLASS="quote">well, how come some ppl talk about h4h??? some sort of jdm bulb type? is this what EK jdm headlights use or no?</TD></TR></TABLE>
H4H is for 5th gens and that bulb has a smaller base I believe.
Old Oct 12, 2007 | 11:06 AM
actek23's Avatar
Default Re: (NOFX)
according to passwordjdm.com
H4H will fit all 1988-1991 EF Civics, 1992-1995 EG Civics, and 1990-1993 DA Integras equipped with JDM headlight housings.
Old Oct 12, 2007 | 11:10 AM
n8dizzel's Avatar
Default Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">The same as any other 6th gen headlight.
H4 aka 9003.</TD></TR></TABLE>
H4 has a much different plug than a 9003
that car would take a H4
Old Oct 12, 2007 | 11:13 AM
gsrpedro's Avatar
9004???
Old Oct 12, 2007 | 11:21 AM
9civic8's Avatar
Default Re: (n8dizzel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n8dizzel &raquo;</TD></TR><TR><TD CLASS="quote">
that car would take a H4</TD></TR></TABLE>
H4 and 9003 is the EXACT same thing.
Old Oct 12, 2007 | 11:40 AM
built562's Avatar
wow... you suck. they are the same
but 6th gens use h4 usdm and jdm
Old Oct 12, 2007 | 11:48 AM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n8dizzel &raquo;</TD></TR><TR><TD CLASS="quote">H4 has a much different plug than a 9003
I will third this.
You are wrong.
In fact, here are some links to back up how wrong you are.
http://www.candlepowerinc.com/pdfs/H4_9003.pdf
http://forums.nasioc.com/forum...10767
http://www.tundrasolutions.com...03-h4/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">In 1991, automakers wanted to use H4 headlight bulbs on cars in the US, but the DOT decided engineering blueprints for H4 bulbs allowed too much variance in the position of the filaments within the bulb. So a new blueprint was made, with all the electrical and dimensional properties the same, but with stricter limits on filament placement variance. Because of the limits in the US on beam intensity in effect in 1991, the maximum allowable light output tolerance was also reduced. This new bulb specification was called "9003/HB2", because at the time, two numbering conventions were in use. Many 9003/HB2 bulbs also carry the "H4" marking, and vice versa, because it is possible to meet the specifications in both blueprints at the same time. The first headlamps with 9003 bulbs were on 1992 model cars.</TD></TR></TABLE>
9003 and H4 bulbs plug into the same sockets, have the same wattage, appear the same and overall look to be the same bulb, save for where the filament can be in the bulb.
It's fine to come in and tell me I'm wrong. But at least be right when you do it.
Old Oct 12, 2007 | 04:30 PM
Andyroo's Avatar
nice! so EKs use 9003 or H4, jdm or usdm, cool! thanks guys
Old Oct 13, 2007 | 12:54 PM
n8dizzel's Avatar
Default Re: (NOFX)
Aight.. got me. Could sworn the plug was different.
nobody perfect. i will just make sure i know my shyt b 4 callin someone wrong. My Bad.
Modified by n8dizzel at 2:07 PM 10/13/2007
OPTION2ek V.2
Jan 15, 2006 01:46 AM
civtrx
Nov 15, 2005 01:06 PM
alphabeatsco
Aug 16, 2005 05:55 AM
DIYaccord
Oct 12, 2004 09:50 AM
