98, teg ignition housing problem..
Old Oct 11, 2007 | 08:48 PM
310Integra's Avatar
Default 98, teg ignition housing problem..
Well ive gone to several shops and they can only sell the whole ignition assembly. i just need the housing so im going to have to go to the junk yards now. I want to know if anyone knows if the housing would be the same in 94-01tegs auto and manual since I will only need the housing. Problem mine was broken. due to theft,now I have to replace it, I knw i have to drill the bolts out, is ther another way to take the breaker bolts off, since i dont want to carry alot of things into the junk yard. i know how to take everything else off. just the part where the breakers bolts are on.. drill is my choice but trying to stay away. let know me what you guys know. thanks and i just remember i can use a punch to loosen them up.. but yah i need input on the housing,
Old Oct 12, 2007 | 02:52 PM
310Integra's Avatar
Default Re: 98, teg ignition housing problem.. (310Integra)
Ok the housings are desing different from the outside, I got one today of a 94 auto teg,. Im going to try see if it works and let you guys know. I heard it doesnt. people didnt give me correct pointers eighter so im by my self, also 92 civic ignitions are the same.. compared it.,.
Old Oct 12, 2007 | 10:01 PM
310Integra's Avatar
Just to let all you guys know it does work... an auto ignition switch my look diff. but its all the same. except it come with other plugs not necessary. I saved my self alot of money doing this. I used a 95 integras auto ignition switch, and all i had to do was swap my key cylinder and that was all.. thanks for reading and seeing my self figure all this out by myself.. by the way this went in a 98 gsr,
usarmy1
Suspension & Brakes
Jun 6, 2005 10:03 AM
RNPoo7
Jan 7, 2005 09:54 PM
PM-Performance
Dec 9, 2002 08:43 AM
Ninjaboi_on_X
Oct 11, 2002 08:50 PM
