urgent!!!! five lug conversion question
Old Oct 11, 2007 | 08:37 PM
dannysolis92005's Avatar
Default urgent!!!! five lug conversion question
I am converting from a four lug to five on a Integra GS w/abs everything from trailing arms to axles was replace but there is a problem w/my abs light
my brake pedal goes to the groung with little resistance and the abs light does not come on when the ignition is in the on position the wheel sensors are the original
and were working properly prior to the conversion what can I Do do do do please help thank you suckes...
Old Oct 11, 2007 | 09:17 PM
BlueIntegraBoy's Avatar
Default Re: urgent!!!! five lug conversion question (dannysolis92005)
How well did you bleed your brakes?
Old Oct 11, 2007 | 09:20 PM
JjuuN R's Avatar
Default Re: urgent!!!! five lug conversion question (BlueIntegraBoy)
Wrong forum...
Old Oct 12, 2007 | 04:11 AM
PrinceAli132's Avatar
Rebleed the brakes. It might take a few cycles to get all the air out.
Ali
Old Oct 12, 2007 | 05:28 AM
Erik95LS's Avatar
Default Re: urgent!!!! five lug conversion question (PrinceAli132)
did you put in the R ABS unit or are you using the older style with its own reservoir?
Old Oct 12, 2007 | 06:08 AM
Doespike's Avatar
5-lug setup + Cali = gotta ask the question....Ya got a receipt? Wouldn't want this forum assisting in the installation of hot kaa parts.
Old Oct 12, 2007 | 07:18 AM
migs's Avatar
Default Re: urgent!!!! five lug conversion question (Doespike)
You need to bleed your master cylinder first before you bleed your slaver cylinder.
Old Oct 12, 2007 | 07:31 AM
Mugen Type R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doespike &raquo;</TD></TR><TR><TD CLASS="quote">5-lug setup + Cali = gotta ask the question....Ya got a receipt? Wouldn't want this forum assisting in the installation of hot kaa parts. </TD></TR></TABLE>
Right on, as Opie would say
GTFO!
EricUSC
21
Apr 18, 2009 05:40 PM
teggy2uner18
Jun 13, 2006 12:42 PM
Nerologic
Dec 21, 2003 07:35 PM
ILOVEGIRLS
Oct 18, 2003 11:57 AM
