obd1 or obd2
Old Oct 11, 2007 | 07:00 PM
JWhonda_ride's Avatar
Default obd1 or obd2
i was wondering which i would need to put a grs swap in my stock 91 crx. any coments would be appreciated
Old Oct 11, 2007 | 09:13 PM
denraweb's Avatar
Default Re: obd1 or obd2 (JWhonda_ride)
NOt sure I understand the question fully, but it's your own personal preference. You can do either, but obd1 will be the better option due to tuning and ecu etc.
Old Oct 11, 2007 | 09:15 PM
Jonknee's Avatar
Default Re: obd1 or obd2 (denraweb)
such a vague question
Old Oct 11, 2007 | 09:16 PM
garageEF's Avatar
obd1 is the better choice.
Old Oct 11, 2007 | 10:05 PM
.Grimace's Avatar
footwork mastery
Default Re: obd1 or obd2 (garageEF)
obd2 is the shitty choice. extra o2 sensor, have to convert your iacv from a 2 wire to a 3 wire, must add a ckp sensor in your oil pump... should i continue?
Modified by .Grimace at 7:12 AM 10/12/2007
Old Oct 11, 2007 | 11:25 PM
garageEF's Avatar
Default Re: obd1 or obd2 (.Grimace)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Grimace &raquo;</TD></TR><TR><TD CLASS="quote">obd2 is the shitty choice. extra o2 sensor, have to convert your iacv from a wire to a 3 wire, must add a ckp sensor in your oil pump... should i continue?</TD></TR></TABLE>
less (and more expensive) engine managment options, emissions BS...
the only upside to going OBDII that i can think of is cheap ecu's
l1l_r1cky
Feb 28, 2012 01:27 AM
turbo97coupe
Mar 31, 2009 07:44 PM
3rdgencrx
Mar 8, 2007 04:34 PM
k24a4kid
Jan 24, 2005 10:05 AM
