Adjusting distributor
Old Oct 11, 2007 | 06:18 PM
Giant_Bean's Avatar
Default Adjusting distributor
When adjusting a distributor what angle are you supposed to look at to line up the pointer and the marks on thel flywheel? I tried to get as close to 90 degrees to the inspection hole as I could, just making sure I was right
Old Oct 11, 2007 | 10:27 PM
preludefien
Guest
Posts: n/a
Default Re: Adjusting distributor (Giant_Bean)
should be a line but u should just get a timing light
Old Oct 12, 2007 | 05:30 AM
Giant_Bean's Avatar
Default Re: Adjusting distributor (preludefien)
i've got a timing light, if you look through the inspection hole at different angles, the position of the marks in relation to the pointer will change
Old Oct 14, 2007 | 05:14 PM
shadow29485's Avatar
That is true.....
Old Oct 14, 2007 | 05:33 PM
Hawkze_2.3's Avatar
Just try to look from as straight above as you can judge. Where the light beam is perpendicular to the flywheel surface and the little pointer.
Warren_LowSol
Jan 18, 2018 12:22 PM
honda1992 20
Mar 29, 2011 02:56 PM
honda3431
Dec 23, 2007 11:05 AM
integmester
Sep 9, 2004 10:21 PM
typeeg
Jun 23, 2004 04:22 AM
