5 lug conversion.ek
Old Oct 11, 2007 | 04:22 PM
BMRALR's Avatar
Default 5 lug conversion.ek
I want to do a 5 lug conversion on 97 civic hatch. will the itr 5 lug conversion with 36 mm axles fit on my car?
Old Oct 11, 2007 | 04:46 PM
doood's Avatar
been there done that
Default Re: 5 lug conversion.ek (BMRALR)
get one with the 32mm hubs. makes finding axles easier.
Old Oct 11, 2007 | 05:04 PM
BMRALR's Avatar
Default Re: 5 lug conversion.ek (doood)
alright what are all the parts i need for the conversion?
Old Oct 11, 2007 | 05:16 PM
92hatchboi's Avatar
front knuckles with spindles and rear trailing arms with ebrake cables. i did it on my eg hatch
Old Oct 11, 2007 | 07:23 PM
BlueIntegraBoy's Avatar
Assuming you have a B-series and the 36mm axles, it will be plug and play.
Old Oct 12, 2007 | 04:13 AM
BMRALR's Avatar
Default Re: 5 lug conversion.ek (BlueIntegraBoy)
i have a b16. plug and play meaning....the 36 mm def. wont fit?
Old Oct 12, 2007 | 05:24 AM
92hatchboi's Avatar
yes it will be plug and play but you might have trouble finding axles when it comes to needing them since its 36mm
Old Oct 12, 2007 | 06:06 AM
BMRALR's Avatar
Default Re: 5 lug conversion.ek (92hatchboi)
axels usually come with the swap? So best bet is to find swap that uses 32 mm to make it easier on myself?
Old Oct 12, 2007 | 10:19 AM
If you can find JDM 98 spec ITR 36mm axles, great. If not, you will need to make custom axles using regular b-series axles with prelude/accord outers.
Old Oct 12, 2007 | 10:26 AM
BMRALR's Avatar
..but if i get CTR 5 lug conversion i can use my stock 32 mm axels on my 97 hatch. Correct me if im wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMRALR &raquo;</TD></TR><TR><TD CLASS="quote">..but if i get CTR 5 lug conversion i can use my stock 32 mm axels on my 97 hatch. Correct me if im wrong. </TD></TR></TABLE>
This is correct
Old Oct 12, 2007 | 10:29 AM
BMRALR's Avatar
http://cgi.ebay.com/ebaymotors...wItem
Would thise particular kit for sale includes everything I need for complete swap. Is anything missing?
Old Oct 12, 2007 | 10:33 AM
Those came off an Integra. The UCAs are not from a 96-00 Civic. So those are probably the 98 spec ITR 5-lugs using 36mm axles if it's from Japan. If you plan to get that set, you will need ebrake cables.
Old Oct 12, 2007 | 10:36 AM
BMRALR's Avatar
it says CTR came off civic type r.?
Old Oct 12, 2007 | 12:46 PM
The UCAs are from an 94-01 Integra/92-95 Civic
Old Oct 12, 2007 | 01:15 PM
vti444's Avatar
on an ek is it poss to just buy rear itr bearings from honda and front bearings along with hub plate and bolt tsraight on to give the 5 stud conversion ?
Old Oct 12, 2007 | 03:16 PM
Default Re: (vti444)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vti444 &raquo;</TD></TR><TR><TD CLASS="quote">on an ek is it poss to just buy rear itr bearings from honda and front bearings along with hub plate and bolt tsraight on to give the 5 stud conversion ?</TD></TR></TABLE>
If using the larger front knuckles (10.3" rotors), then you can buy hubs, bearings, and calipers to convert. I believe the EK4 does have the larger knuckle.
Old Oct 12, 2007 | 03:37 PM
Aquafina's Avatar
Default Re: (BlueIntegraBoy)
Easiest thing to do is just get the CTR conversion. Other than the rear brake lines, it was completely bolt on for my 96 DX.
Old Oct 12, 2007 | 04:10 PM
BMRALR's Avatar
Default Re: (Aquafina)
isnt this a CTR lug conversion...?
Old Oct 13, 2007 | 05:15 AM
vti444's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
If using the larger front knuckles (10.3" rotors), then you can buy hubs, bearings, and calipers to convert. I believe the EK4 does have the larger knuckle.</TD></TR></TABLE>
im running legend 282mm brake setup already
Old Oct 13, 2007 | 06:57 AM
polything's Avatar
your car has rear drum brakes right?
you will need better brake booster (integra), rear disc brake proportional valve from civic SI or integra , rear brake lines too.
here is some more info:
https://honda-tech.com/zerothread?id=2073128
https://honda-tech.com/zerothread?id=2068474
https://honda-tech.com/zerothread?id=2116747
and yeah, BUY CTR or USDM ITR 5 lugs or JDM CTR 32 mm, dont buy the JDM ITR one...such an hassle for 36mm hub.
i have 36mm, still working on the axles,
Tim1982
Jun 30, 2013 08:09 PM
TA Performance
May 9, 2007 12:46 PM
RhdRicheeee
Nov 21, 2005 04:06 PM
KiNG $h!t
Sep 19, 2004 06:36 PM
jdmjohn02
Jan 10, 2004 05:39 PM
