Completely stumped
Old Oct 11, 2007 | 02:44 PM
95silverluder's Avatar
Default Completely stumped
So my car doesnt stop sputtering. I've replaced the piping from the first flange to the muffler, along with the muffler, had a major tune up, my cat is perfectly fine. Anyone have any ideas to what it could be. Thanks for any help in advance.
Old Oct 11, 2007 | 04:05 PM
mgags7's Avatar
please edit your name so I don't have to look at that ugly mess of capatalization errors every time I click on one of your threads.
What do you mean by sputtering? It just sounds bad or it doesn't run quite right?
Old Oct 11, 2007 | 10:34 PM
preludefien
Guest
Posts: n/a
Default Re: (mgags7)
so ******* harsh these days matt...you need to get some of that built up testosterone out...
Old Oct 12, 2007 | 05:03 AM
I don't really know the exact words to explain it, but its kind of like a pft at idle, and when i'm accelerating it jerks a small amount. Its usually only in idle and 5th.
Old Oct 12, 2007 | 05:10 AM
mgags7's Avatar
check the flexpipe on the header. Its probably frayed and leaking.
Chris, you're right lol. I've been working ridiculous hours this week tho so I haven't been able to do ****....
Old Oct 12, 2007 | 05:13 AM
so what do I do about that?
Old Oct 12, 2007 | 07:28 AM
NirVTEC's Avatar
Default Re: (preludefien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien &raquo;</TD></TR><TR><TD CLASS="quote">so ******* harsh these days matt...you need to get some of that built up testosterone out... </TD></TR></TABLE>
He needs a FLESHLIGHT!
Old Oct 12, 2007 | 09:31 AM
AaronW's Avatar
Default Re: (95silverluder)
Check the flex piping coming off the motor. Get underneath the car and look for either a crack or hole or rust or something. Your pipes may be coming apart as well, if bolts aren't secure.
If there's a hole, you're probably better off just replacing it, rather than trying to repair it.
Old Oct 12, 2007 | 10:00 AM
preludefien
Guest
Posts: n/a
Default Re: (::NirVTEC::)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ::NirVTEC:: &raquo;</TD></TR><TR><TD CLASS="quote">
He needs a FLESHLIGHT! </TD></TR></TABLE>lol ive heard of those things but we wolfpack puppies prefer the real thing
Old Oct 12, 2007 | 10:35 AM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien &raquo;</TD></TR><TR><TD CLASS="quote">lol ive heard of those things but we wolfpack puppies prefer the real thing</TD></TR></TABLE>
who doesn't.....the FLESHLIGHT doesn't come with all the bitching though!
hahaha!
Old Oct 12, 2007 | 08:23 PM
Tip14's Avatar
Just a thought but if youre driving around in 5th going less than 40mph it isnt going to exactly get up and go cause you're not using the right gear it's going to sputter a little until it reachs the higher rpms. Just my two cents
Old Oct 12, 2007 | 08:49 PM
j0KeRzWilD's Avatar
Default Re: (Tip14)
i know that everyone talking about your pipes....but i was just wondering if this started after you did the tune up??? and also, what do you mean by MAJOR YUNE UP..... what do you consider major???.....so we know what/where to start..
if it did start after your tuneup or shortly after it id chech out the parts that were replaced or tuned...pretty much back track if you havent already...just to make sure all is within oem specs....
GL...
keep us posted
Old Oct 12, 2007 | 09:11 PM
boostedh22lude1's Avatar
Default Re: (j0KeRzWilD)
check ur injectors.
Old Oct 13, 2007 | 06:38 AM
Rob97'SH's Avatar
Well I don't know why people are saying check your exhaust if like you said it jerks on accell. I would check the plugs and timing.
Old Oct 13, 2007 | 07:22 AM
dustin_bb6's Avatar
what kind of spark plugs you got in it. they should be platinum or better otherwise they foul out fast. NGK 7100 are the plugs i would use in that. and check your plug wires
Old Oct 13, 2007 | 03:21 PM
Default Re: (dustin_bb6)
its almost stopped jerking since i fixed the exhaust, but it still does everynow and again.
jimmer21
Honda CR-V & Element
Mar 1, 2019 11:02 AM
Casinbean
16
Mar 26, 2008 10:56 AM
fongph
Oct 26, 2005 08:59 PM
mattcalica
Nov 25, 2003 07:52 PM
X2BOARD
Aug 31, 2003 08:59 AM
