turbo parts
Old Oct 11, 2007 | 01:05 PM
striker.2006's Avatar
Default turbo parts
i have a 1995 integra gsr with 175000 miles on it and im trying to turbo it what internal engine parts do i need and what should i do to prepare for the build I.E. cooling system or other parts that will help to increase the life of the engine thanks
Old Oct 11, 2007 | 01:16 PM
Zappythebum's Avatar
Default Re: turbo parts (striker.2006)
with 175000 miles on it.. jesus, i dont know if that engine can take much more... let alone a turbo.. you might want to look into rebuilding it, or even getting a new one before mentioning anything else about a turbo.
doood's Avatar
been there done that
do compression and leakdown tests. if those come out good, boost away.
if you want to boost and not have to worry about a rod breaking or piston melting, forged rods and pistons and new bearings are a good idea. but remember, with a shitty tune even the best parts will go to ****.
Old Oct 11, 2007 | 01:28 PM
Default Re: turbo parts (Zappythebum)
with the rebuild i just replace the rods pistons bearings and the head studs or should i replace the crankshaft to
Default Re: turbo parts (doood)
how much do compression and leakdown test usually cost
Old Oct 11, 2007 | 01:30 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by striker.2006 &raquo;</TD></TR><TR><TD CLASS="quote">with the rebuild i just replace the rods pistons bearings and the head studs or should i replace the crankshaft to</TD></TR></TABLE>
unless the crank spun a bearing it's fine. wouldnt hurt to get it micropolished and balanced.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by striker.2006 &raquo;</TD></TR><TR><TD CLASS="quote">how much do compression and leakdown test usually cost
you can get a compression tester for $30 and do it yourself. you'd need an air compressor for a leakdown though.
Old Oct 11, 2007 | 01:35 PM
i have someone that is trying to sell me a micropolished crankshaft connecting rods and pistons for 500 he says they have low miles on them but what do i look for or should i take them to a shop and have them looked at
Old Oct 11, 2007 | 01:40 PM
doood's Avatar
from what engine? have them checked out first.
Old Oct 11, 2007 | 01:41 PM
a b 18 engine i was going to have them checked out any way but i just wanted to know if there is anything that i can look for right off so i dont waste my time
newtothescene
Apr 5, 2008 04:53 PM
got2luvdarice13
Sep 18, 2007 04:57 PM
blakh
Aug 7, 2005 03:10 PM
ftemanuele
Dec 14, 2004 03:04 PM
vpforeva
Jan 16, 2002 01:55 PM
