ROCKERS
Old Oct 11, 2007 | 12:15 PM
DrivinVtec's Avatar
Default ROCKERS
Are h23 an f22 the same as a h22 rockers? I need some. Mine are warn for soem reason. The vtec ones are fine just the small one.
Old Oct 11, 2007 | 12:22 PM
117's Avatar
117
Default Re: ROCKERS (DrivinVtec)
The H22 rockers are machined as a set. You cannot replace just one rocker. You must replace all three as a set.
Old Oct 11, 2007 | 12:44 PM
DrivinVtec's Avatar
Default Re: ROCKERS (117)
so ever h22 head is different?
Old Oct 11, 2007 | 12:51 PM
DrivinVtec's Avatar
what are compatible rockers with the h22a4?
Old Oct 11, 2007 | 01:00 PM
Eddiebx's Avatar
every set of rockers are different, u have to kepp all 3 together when moving it around
Old Oct 11, 2007 | 01:16 PM
DrivinVtec's Avatar
Default Re: ROCKERS (Eddiebx)
ohhh..okay. i see. a set of thee..not all of them
Old Oct 11, 2007 | 01:23 PM
DrivinVtec's Avatar
since my rocker are warn... what are the negs. ? After i get this rebuild it going to the dyno then im hitting the road to NH from CA. I onlt get maybe 300whp because of the injecters? SO what im asking would i run into problem if dyned then drive home? I dont want to run into trouble.
Old Oct 11, 2007 | 01:56 PM
117's Avatar
117
If the rockers are worn, replace them and the cams.
Old Oct 11, 2007 | 04:02 PM
h22 civic's Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">If the rockers are worn, replace them and the cams.</TD></TR></TABLE>
yupppper.......u could quite possibly drop a valve
Old Oct 11, 2007 | 04:04 PM
DrivinVtec's Avatar
the machine shop said the cams are fine.
Old Oct 11, 2007 | 04:56 PM
117's Avatar
117
If the rockers are wadded up, I would NOT reuse the cams unless you have them refinished. You're begging for trouble if you just throw the cams back in.
Old Oct 11, 2007 | 05:01 PM
DrivinVtec's Avatar
Default Re: (117)
wadded?
Old Oct 11, 2007 | 05:08 PM
117's Avatar
117
Damaged.
Old Oct 11, 2007 | 05:09 PM
DrivinVtec's Avatar
Default Re: (117)
there not.
Old Oct 11, 2007 | 05:12 PM
117's Avatar
117
So what do you mean by worn? When I think of worn, I think of something that's abnormal, like divots in the rocker pads.
Old Oct 11, 2007 | 05:14 PM
DrivinVtec's Avatar
Default Re: (117)
yup. this si what the machine shop thinks. weak spring cause the rocker pad hit the cam. the cams look fine. just wear on the pads.
i personlly havent seen the cams but according to these guys there fine.
Old Oct 12, 2007 | 06:00 PM
h22 civic's Avatar
Default Re: (DrivinVtec)
ANY flat spots on the cams or rockers JUNK'EM!!
badassCRX
Oct 11, 2007 06:07 PM
ge_itr
Feb 21, 2007 08:21 AM
LudeyKrus
May 30, 2004 09:52 AM
Greyout
Nov 20, 2002 05:26 PM
