can someone tell me the name of this hose???
Old Oct 11, 2007 | 12:04 PM
EkPudge's Avatar
Default can someone tell me the name of this hose??? updated pic added
im assuming its a coolant hose cause anti-freeze is leaking out of it...it about 5 inches and is located on the left side of the intake manifold near the head(right below the throttle)...it loops down and connect right below...thanks
Modified by EkPudge at 2:20 PM 10/11/2007
Modified by EkPudge at 2:36 PM 10/11/2007
Old Oct 11, 2007 | 12:32 PM
tougeR's Avatar
(I cant see pics because I am at school, but...)
It's probly your throttle body heater hose, it sends coolant through it to warm the TB on super cold days. Useless really unless you are in 20-* weather.
Old Oct 11, 2007 | 12:35 PM
Duane_in_Japan's Avatar
Default Re: (tougeR)
If there is a hose going in, where is the other hose coming out located.
Old Oct 11, 2007 | 01:10 PM
EkPudge's Avatar
Default Re: (Duane_in_Japan)
the hose connects at the intake manifold like i explained above and then it loops down and looks like it goes to the block its abput half the size of a radiator hose and about 5 inches
Old Oct 11, 2007 | 01:15 PM
EkPudge's Avatar
Default Re: (EkPudge)
im a take a pic and show you just give me a sec
Old Oct 11, 2007 | 01:16 PM
FITV hose, it should be in two pieces, an inlet and an outlet, maybe it looks like one hose but there should be a metal t fitting in the middle under the throttle body. Is this not it. You must have some small radiator hoses.
Old Oct 11, 2007 | 01:17 PM
EkPudge's Avatar
i got the top clamp off just the bottom is giving me problems does anyone know the name?
Old Oct 11, 2007 | 02:21 PM
HGZ's Avatar
HGZ
youre talking about the horseshoe looking hose right? i've had that hose burst on me last year. i don't think i ever found out the name but i just took it off and went to autozone and showed it to them and they were able to find a replacement no prob. wasn't too expensive either..
Old Oct 11, 2007 | 02:34 PM
1158's Avatar
You're talking about the hose that goes from the manifold/head to the t-stat housing, right? I've never been able to find out what it's called. It's not even listed in the Helms manual. It shows it, but doesn't have a name.
Old Oct 11, 2007 | 02:55 PM
EkPudge's Avatar
Default Re: (1158)
yeah its the horseshoe shaped one and it does go from the intake manifold to what i guess wou;d be the t housing thing....i fixed it tho just took the hose off and cut it at both ends and clamped it back up...no leaks everythings good thanks guys
Old Oct 11, 2007 | 02:57 PM
1158's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkPudge &raquo;</TD></TR><TR><TD CLASS="quote">yeah its the horseshoe shaped one and it does go from the intake manifold to what i guess wou;d be the t housing thing....i fixed it tho just took the hose off and cut it at both ends and clamped it back up...no leaks everythings good thanks guys</TD></TR></TABLE>
That's what I had to do with mine. On a GSR it's a tight bend and then when I added the S2 manifold, well it made the bend even tighter because the manifold flange is thicker. Glad you got it to work.
Old Oct 11, 2007 | 03:02 PM
u n v kenny's Avatar
Default Re: can someone tell me the name of this hose??? updated pic added (EkPudge)
Hope this diag helps you more than a helms.
Pick the number and let me know, i'll tell you the name of it.
Old Oct 11, 2007 | 03:04 PM
1158's Avatar
Default Re: can someone tell me the name of this hose??? updated pic added (u n v kenny)
13
Old Oct 11, 2007 | 03:05 PM
EkPudge's Avatar
its actually a 93 integra but #3 is what it looks like but its in a diffretn spot on mine
Old Oct 11, 2007 | 03:07 PM
myfirstdc2's Avatar
u talking about the oil cooler hose?
Default Re: can someone tell me the name of this hose??? updated pic added (1158)
Wax inlet hose.
$6 shipped
1158's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkPudge &raquo;</TD></TR><TR><TD CLASS="quote">its actually a 93 integra but #3 is what it looks like but its in a diffretn spot on mine</TD></TR></TABLE>
It's different on a GSR, much smaller. On a B18a/b it's in a similar location but is larger. It would be great if he could post up a pic of the b18a/b.
Old Oct 11, 2007 | 03:10 PM
myfirstdc2's Avatar
if its off teh 93 hes probally talking about the bypass oulet. next time u should state car and model for ease of help
Old Oct 11, 2007 | 03:13 PM
Default Re: can someone tell me the name of this hose??? updated pic added (myfirstdc2)
Ok here's the pic for a 93 LS
Old Oct 11, 2007 | 03:20 PM
1158's Avatar
Based on the OP description I would guess #3 for him. What is #9 called on the GSR, is it different for a 98 GSR? The more I look at it the more I think that may be the one I was talking about. All the lines ran together for me.
Old Oct 11, 2007 | 03:29 PM
#9 on the GSR pic and the same from 94-01 is the Bypass Outlet Hose
Old Oct 11, 2007 | 03:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myfirstdc2 &raquo;</TD></TR><TR><TD CLASS="quote">if its off teh 93 hes probally talking about the bypass oulet. next time u should state car and model for ease of help</TD></TR></TABLE>
+1 LOL
Old Oct 11, 2007 | 05:32 PM
EkPudge's Avatar
yeah its number 3
Old Oct 12, 2007 | 04:11 AM
Bypass outlet hose
PN: 19508-PM6-000
List: $5.92
$7 shipped to you.
turbogenetic
Jun 1, 2009 12:20 PM
GetawayInMoscow
Jul 25, 2007 08:09 PM
crxpwr1
28
Jan 24, 2007 06:47 PM
joebark
Sep 27, 2004 08:25 PM
confucius
Jan 27, 2002 06:09 PM
