brake light question
Old Oct 11, 2007 | 11:41 AM
nighthawkgsr's Avatar
Default brake light question
hello everyone, i recently got my 96 ex back from the paint shop and i realized that the shop broke one of the bulbs in the back tailights. it was the brake light bulb. now the both brake lights don't function. wth is goin on? fuse? short? idk. any help would be appreciated.
Old Oct 11, 2007 | 11:48 AM
djessenz's Avatar
Default Re: brake light question (nighthawkgsr)
I'd say its a short in the wiring somewhere
Old Oct 11, 2007 | 11:49 AM
skateboard_ej8's Avatar
im hench irl
Have you replaced both reverse light bulbs?
Old Oct 11, 2007 | 12:36 PM
Default Re: brake light question (esco562)
I'm goin to replace the bulbs today, but I don't understand why the lights are not working, it was functioning great until i got it back from the shop and the bulb was busted in the socket.
Old Oct 11, 2007 | 02:04 PM
bump for help cuz i have to drive to work tonight.
Old Oct 11, 2007 | 05:50 PM
Ok replaced bulbs check brake light switch and still no brake lights! What should I do next? I called in cause I didn't want to risk getting into a accident.
Old Oct 11, 2007 | 08:06 PM
Bump I need help!
Old Oct 11, 2007 | 08:11 PM
stock_honda_coupe's Avatar
Check all the fuses? Sound like you've got a wireing problem. Check for power and ground with a multimeter to get started. A test light will work too if you don't have a multimeter
Old Oct 12, 2007 | 08:58 AM
Default Re: brake light question (stock_honda_coupe)
fuses are all good. so i guess its a short, my question is how do i fix it.
Old Oct 12, 2007 | 09:21 AM
n8dizzel's Avatar
This is a long shot but check all the plugs that are about about 6-10 inches from the light ballast. and check all your fuses under the dash as well as under the hood. Use a multimeter to see if your getting any current at all the the socket. Last but not least... Call the paint shop and tell then they screwed up your car and you want some compensation for your trouble and tell them you lost a day of work because of them.
Old Oct 12, 2007 | 09:41 AM
Default Re: brake light question (n8dizzel)
thanks everyone for your help ill update when i find out the problem, until then keep giving me your input of my little problem
Old Oct 12, 2007 | 10:46 AM
Ok update, I recheck the under the dash fuse box and fuse #32 (tailights) broke I replaced the fuse with another 7.5 fuse and still no brake lights.
Old Oct 12, 2007 | 10:48 AM
Jizzmaster Zero's Avatar
(banned)
What should you do? Make the idiots at the shop who broke it, fix it.
Old Oct 12, 2007 | 11:40 AM
Default Re: brake light question (Jizzmaster Zero)
Do u guys think this will be a costly fix? If so ill go to the paint shop to ask them to fix it, but i don't want some paint and body guys messing with my wiring.
Old Oct 12, 2007 | 10:11 PM
Bump for latenight imput working on the car as we speak, using sidekick to look on honda-tech
Old Oct 12, 2007 | 10:16 PM
hmtcrxsir's Avatar
does the third brake light work? it may be the brake switch. forgot what its called. Its the switch that behind the brake pedal. If thats busted none of your brake light will work. If the wirings and fuses seem to be ok then this may be your problem.
professorman
Oct 27, 2013 06:28 AM
caseythefalcon
Mar 30, 2013 03:24 PM
djevolution04
Honda Civic (2001 - 2005)
Nov 8, 2011 06:47 AM
94civicoupe
Oct 16, 2006 06:09 PM
JdmLsPwr425
May 4, 2004 03:58 AM
