Temperature control, '89 CRX
Old Oct 11, 2007 | 11:32 AM
woofpak92's Avatar
Default Temperature control, '89 CRX
I have had this '89 CRX since the spring and the temperature control dial has always been stuck in the cold position. The plastic is cracked around the dial, so I'm not sure what happened to it. Now that it's about to turn cold, I need to have a means for some heat. The place I get the car worked on (I've used them for 10+ years) tells me to fix this requires the replacement of the whole temperature panel assembly.
A: is this true
B: how do you reference this part number if scouring the web or junk yards, etc
C: is there a "fix" that I could do to get me through the winter months? Can I jump a wire or cable and keep it in warm mode (same way it's stuck in cold mode now)?
Any information anyone out there has, I'd be appreciative.
Old Oct 11, 2007 | 11:38 AM
jamclaur's Avatar
If the control is broke go to the junk yard and find one that looks the same from a Ef and buy it.
Old Oct 11, 2007 | 11:39 AM
Stefndogg's Avatar
Default Re: (jamclaur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamclaur &raquo;</TD></TR><TR><TD CLASS="quote">If the control is broke go to the junk yard and find one that looks the same from a Ef and buy it.</TD></TR></TABLE>
finding the correct crx climate control that is not cracked is really rare.....i had a mint one from my old car that i sold for 180bucks.....you could do this
https://honda-tech.com/zerothread?id=1434022
Old Mar 17, 2010 | 04:12 PM
89crxsi89's Avatar
Default Re: Temperature control, '89 CRX
My 89 crx si had the same problem. you can take the whole climate control out and unscrew the temperature selector off then remove the cables from their respective clamps (one is under the hood attached to the heater hose and the other is accessed via the passenger side under the dash).
The Honda part number is: 79510-SH2-A01
but is useless because they don't make it anymore.
I'm currently on the search for one too.
You could disconnect the cables from their clamps and turn them in a way that will give you heat. I don't know which way opens the valve but I'm sure alittle trial and error would get you through it.
Old Mar 17, 2010 | 04:34 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
From the FAQ section at the top of CRX/EF forum:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/heat-not-working-2225295/
Old Mar 18, 2010 | 09:30 AM
JOE BD-0's Avatar
If any one is interested, I have two climate controls for sale. One has the AC button and one doesn't. Both were from 88-91 ef hatches and both have the long control wires attached. Hit me up. Good Luck.
Old Mar 18, 2010 | 09:42 AM
89crxsi89's Avatar
are those the same as the crx one? cause all the one's ive seen at the junk yard in ef hatches are different from mine
Old Mar 18, 2010 | 09:45 AM
Deetz's Avatar
Crazy Honda Guy
Not sure....i live in Canada, but i was able to go to the local Hinda dealer and buy a brand new control, no problem ...it was a couple years ago i did this though
Old Mar 18, 2010 | 09:49 AM
89crxsi89's Avatar
that looks like mine! but do you have the temperature selector unit?
Old Mar 18, 2010 | 09:55 AM
Deetz's Avatar
Crazy Honda Guy
Mine was good, i didn't have any need to order the **** and parts behind it, they are not problem known parts
Old Mar 18, 2010 | 09:58 AM
89crxsi89's Avatar
yeah. I went to honda last week and they told me that the temp selector is no longer made... which sucks cause that the part i need
Old Mar 18, 2010 | 10:04 AM
CRX Toad's Avatar
http://www.instructables.com/id/CRX-...-Installation/
Old Mar 18, 2010 | 10:19 AM
Deetz's Avatar
Crazy Honda Guy
hmm, that's funny, i just made a call 5 mins ago and ordered the part myself, part number 5
(# 79510-SH2-A01)
Old Mar 18, 2010 | 11:10 AM
89crxsi89's Avatar
(# 79510-SH2-A01)
well thats what they said at Gladstone honda. And i tried ordering it from this (http://www.hondapartsdeals.com/) website and my order went through but then they emailed me 3 days later saying honda no longer makes it. let me know if you actually get the part cause i need one!
Old Mar 18, 2010 | 11:14 AM
Deetz's Avatar
Crazy Honda Guy
I checked stock, i got the last one in Canada, but after that, they are still available on a back order from Japan. I think it's a month b/o.
I'm out of town till Tues, once i'm back, i'll take pics for you
Old Mar 18, 2010 | 11:47 AM
89crxsi89's Avatar
cool i appreciate it!
Old Mar 26, 2010 | 01:10 PM
Deetz's Avatar
Crazy Honda Guy
I'm out of town, once i'm back, i'll take pics for you
As promised
Old Mar 27, 2010 | 12:40 AM
89crxsi89's Avatar
o how i dream of this piece... i found one at a junk yard and was so happy that the shaft wasn't broken, i didn't look at the rest of it. It ended up being useless
Old Mar 27, 2010 | 07:18 AM
scottmog's Avatar
i have uncracked crx climate controls for 200 a piece shipped. they come with new ***** and a/c ***** that still make clicking sounds when you press them.
these are not fixed with plate climate controls, these have never been cracked. i can also put aerospace grade two part epoxy on the back where the unit usually crack with the buyer wants
MrNobody13
Oct 14, 2006 07:44 AM
01h22lude
Sep 24, 2004 06:29 PM
iNetForce
Apr 3, 2004 07:34 PM
Grease Monkey
Jan 19, 2004 02:42 PM
DsMWookie
Sep 3, 2003 11:21 AM
