threw a code 41 oxygen sensor heater
so i swaped in a 95 EX d16z6 motor in my 94 VX. threw a code 41 oxygen sensor heater. what the hell does this mean? do i have to get a new o2 sensor? thanks in advance.
Vx = 5 wire O2 sensor
Z6 = 4 wire O2 sensor
Did you do any re-wiring for the Z6's O2 sensor to plug into your existing Vx engine harness?
i swap'd in a d16z6 motor with the z6 engine harness. i just added the vtec solenoid wire, and pressure switch wires from the fuse box plug to a p28 ecu.
i guess ill buy a new o2 sensor. are those Denzo o2 sensors on ebay worth looking into?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808k20a2 »</TD></TR><TR><TD CLASS="quote">i swap'd in a d16z6 motor with the z6 engine harness. i just added the vtec solenoid wire, and pressure switch wires from the fuse box plug to a p28 ecu.
i guess ill buy a new o2 sensor. are those Denzo o2 sensors on ebay worth looking into?</TD></TR></TABLE>
the VX has the VTEC wires in place all ready. to swap in the Z6 with the Z6 engine harness you have to move one wire from the passenger side shock tower plugs to line up with the engine harness plugs. other wise it's completely plug and play.
Since you are running a Z6 now, please tell me you're running a P28 and not the VX's P07.
if you have a multi-meter measure the O2 heater's resistance to check if you have to spend the money. It could be a simple wiring problem.
JoshJosephKeith
May 4, 2009 04:38 PM
DALE-EK4
40
May 3, 2007 11:41 AM
so simple
Nov 24, 2004 10:54 AM
