IS THIS POSSIBLE?
I was going to rebuild my motor since it smokes and the waterpump seized up. while looking under the hood i notice the previous owner kinked the the coolant hose at the bottom. now i noticed that the motor smokes under serious load(bogging like load)which makes me wonder if the waterpump is working extra cause of the kink than it would cause extra load at the crank+rods+pist. resulting in blowby? could this be possible any help would be accepted
i dont think that would happen normally excessive blow by is cause by a bad pcv valve causing excessive crank case pressures and most likely bad compression rings causing excessive blow by on the rings. the kink in the hose probably restricted flow to the coolant pump and the pump need coolant as a lubricant or else it will run too hot.
