weird sound
Old Oct 10, 2007 | 07:09 PM
marecco's Avatar
Default weird sound
i have a d16z6 in my 95 del sol and i have a skunk2 intake manifold and an intake on it and during certain acceleration or throttle movement i get this really high pitched sound.... not the intake this isnt my first car... im thinking maybe the gasket between the throttle body and intake manifold could be leaking? any other suggestions would be great
Old Oct 10, 2007 | 07:14 PM
electron_si's Avatar
Default Re: weird sound (marecco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marecco &raquo;</TD></TR><TR><TD CLASS="quote">i have a d16z6 in my 95 del sol and i have a skunk2 intake manifold and an intake on it and during certain acceleration or throttle movement i get this really high pitched sound.... not the intake this isnt my first car... im thinking maybe the gasket between the throttle body and intake manifold could be leaking? any other suggestions would be great </TD></TR></TABLE>
somone mentioned the air flowing over the TB making a whistling noise. Just a thought, my car makes that noise as well as my friends gsr with a skunk 2 IM
Old Oct 10, 2007 | 07:15 PM
marecco's Avatar
its like a weird very distintctive sound can hear it outside the car and everyhting
Old Oct 11, 2007 | 09:34 PM
marecco's Avatar
bump any suggestions?
Old Oct 12, 2007 | 02:48 AM
r8dr47's Avatar
did you double check on your throttle body??? try checking to see if you didn't tightend the bolts to from the tb to the intake mani..
Old Oct 12, 2007 | 09:19 AM
Kiddox's Avatar
everything is fine. same mine!!!.. my friend hear that sound think it turbo sound.. LOL
Old Oct 12, 2007 | 10:18 AM
Blk00EJ8's Avatar
Default Re:
My Skunk2 68 mm throttle body "whistles" at certain throttle %... nothing wrong if yours sounds like that.
Old Oct 12, 2007 | 04:55 PM
marecco's Avatar
i have just the skunk2 manifold with a stock throttle body. but im thinking its prolly the manifold maybe the gasket tho.
Old Oct 12, 2007 | 08:05 PM
Blk00EJ8's Avatar
Default Re: (marecco)
Are there any vacuum leaks when it idles? If not then I'm inclined to say that if you hear something only when there is a throttle delta, then it's not a gasket leaking or else you would be aware of it all the time.
Old Oct 12, 2007 | 08:30 PM
marecco's Avatar
im pretty sure there isnt it stays pretty steady at idle maybe just a little fluctuation here and there. but i think the gasket may have been like broken sorta on one side when it got installed so could this slight brake make that sound?
Old Oct 15, 2007 | 06:58 AM
Blk00EJ8's Avatar
I highly doubt it. Air is going to move where it's easiest to do so, in other words, if your throttle is open then air is going to be rushing in through your intake arm and past your throttle plate. It's not going to be seeping in from a slight break in the gasket. You will notice a leaky gasket on idle, not when throttle is open.
PEK*EGGEM
Mar 8, 2009 01:55 PM
Circa
Apr 2, 2006 07:05 PM
TODA GS_R
Sep 19, 2005 02:01 AM
Integacivic
Jul 31, 2004 01:59 PM
97 BB6
Sep 15, 2003 05:10 PM
