how to check transmition oil
Old Oct 10, 2007 | 03:21 PM
dodger007's Avatar
Default how to check transmition oil
i have a 00 prelude and coming off of first gear it sounds kinda of nasty, like a dry squeak noise. i wanted to know how to check the oil on a manual transmission?
Old Oct 10, 2007 | 04:36 PM
mgags7's Avatar
You could start with a manual for your car.
You can't really "check" the fluid in the traditional sense, it requires quite a bit of work to make sure it is even at the correct level.
Your best bet is to just drain and refill it with fresh oil. It isn't expensive.
Old Oct 10, 2007 | 06:13 PM
InvaderTrax's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">You could start with a manual for your car.
Your best bet is to just drain and refill it with fresh oil. It isn't expensive.</TD></TR></TABLE>
And, if it's never been done, can benefit your transmission's longevity
Old Oct 10, 2007 | 06:29 PM
snobordboy's Avatar
Moderator
Yeah its cheap even with Honda MTF, use Redline and then it gets expensive, but shifting is super nice!
Old Oct 10, 2007 | 06:35 PM
GraphiteMW's Avatar
Wheres the easiest place to a access hole to fill the tranny up with fluid?
Old Oct 10, 2007 | 06:36 PM
mgags7's Avatar
The only place to fill it up is behind the 17mm bolt which is directly above the fill bolt.
Old Oct 11, 2007 | 10:52 AM
dodger007's Avatar
so best bet is to just drain it and put new one in it?
Old Oct 11, 2007 | 10:59 AM
Pilky's Avatar
Default Re: (dodger007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dodger007 &raquo;</TD></TR><TR><TD CLASS="quote">so best bet is to just drain it and put new one in it?</TD></TR></TABLE>
Ya might as well while your under there. I mean you've obviously never changed it before so while youre in there get the piece of mine knowing you got new oil in there.
Old Oct 12, 2007 | 04:11 PM
yOnKiNaToR's Avatar
Default Re: (Pilky)
i fill my tranny fluid through the hole in the shifter housing from the top of the car.
Old Oct 12, 2007 | 04:17 PM
dagle's Avatar
Default Re: (yOnKiNaToR)
is it really a 2step process? drain + refill? someone gimme a dummy guide, i wonder if that magical honda MTF will fix my shiftforks too!
Old Oct 12, 2007 | 05:55 PM
Prudz_lude's Avatar
Default Re: (dagle)
dont use honda mtf, go to GM and buy GM syncromesh transmission fluid. It actually eliminates grinds. Im not BSing you either. The stuff is amazing and better than redline and so on. I put that stuff in my new tranny and it feels like butter. Slicing a hot knife through butter every shift lol
Old Mar 6, 2008 | 10:47 PM
Dinaris's Avatar
haw about for a Honda Prelude SI 1992. Is is the same way to change the oil in manual transmission? and wich one will be better?
Thanks for responds...
Crossbreeder
Sep 24, 2009 09:18 AM
EK_B
Oct 28, 2007 02:39 PM
keeblerdog8
Oct 13, 2005 01:24 PM
byronl
Jul 10, 2005 10:45 PM
Rah Rah
Feb 1, 2002 10:19 PM
