Does your tranny make noise?
Old Oct 10, 2007 | 11:19 AM
citrus3000psi's Avatar
Default Does your tranny make noise?
I feel like over time my transmission is getting louder. Buts its hard to tell...
First I don't remember this happening before but when you let out on the clutch I hear a noise coming from the tranny. Im just wondering if other Type r owners hear tranny noise when in neutral with the clutch out.
It sounds like a bearing noise more than anything.
Old Oct 10, 2007 | 11:25 AM
RTW DC2R's Avatar
Default Re: Does your tranny make noise? (citrus3000psi)
my trans has been making noise since as long as I can remember. its more of a whining noise than anything else, almost like a supercharger, and happens mainly in 4th and 5th gears. 4th gear especially Ive replaced almost all the bearings in the trans/flywheel and it has never gone away. it goes away when pushing the clutch in and is really only noticable at this point at low RPM in 4th and 5th. I just learn to not even worry about it anymore.
Old Oct 10, 2007 | 11:28 AM
Im saying parked, not reving, the car at 800 rpms. I push the clutch in. Noise goes away, let the clutch out makes noise comes back.
I've experience same whin your talking about. But thats always done that.
Old Oct 10, 2007 | 12:09 PM
redline32's Avatar
Default Re: (citrus3000psi)
its your flywheel spinning,,possibly a bad pilot bearing
Old Oct 10, 2007 | 12:12 PM
RRRRRRRR's Avatar
Default Re: (redline32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redline32 &raquo;</TD></TR><TR><TD CLASS="quote"> bearing</TD></TR></TABLE> will be dropping the tranny later this year.
Old Oct 10, 2007 | 12:31 PM
ITR184's Avatar
Default Re: (-R-)
I get the same noise. I replaced the flywheel, clutch, pilot bearing, and throw out bearing about 9k miles back. I have had the car since new, and can't remember if that is the way it has always been.
Old Oct 10, 2007 | 12:37 PM
Default Re: (-R-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -R- &raquo;</TD></TR><TR><TD CLASS="quote"> will be dropping the tranny later this year.</TD></TR></TABLE>
I replaced the clutch, pressure plate, flywheel, (pilot bearing) last year.
So the parts are fairly new? If something is wrong I would love to have it be the pilot bearing. How often do bearings go bad in the transmission? And if they start to go bad how long do I have?
Old Oct 10, 2007 | 12:40 PM
redline32's Avatar
I had a gsr make that noise no matter the bearing for 60k til I sold her no probs just a little noise
Old Oct 10, 2007 | 01:18 PM
SilverDc2's Avatar
my s2000 makes the same noise, its the bearing, do you remove any panels?
Old Oct 10, 2007 | 01:40 PM
MadSuRfEr's Avatar
Default Re: (SilverDc2)
its the input shaft bearing. i have the same noise and thats what my buddy thats an acura tech told me.
Old Oct 10, 2007 | 01:55 PM
The Kernel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">Im saying parked, not reving, the car at 800 rpms. I push the clutch in. Noise goes away, let the clutch out makes noise comes back.
I've experience same whin your talking about. But thats always done that.</TD></TR></TABLE>
I think I'm getting the same noise. Not all the time but most of the time. It started doing it around 22k miles and I'm around 34k now.
Is this something that needs attention or can I let it go unless it starts to sound worse?
Old Oct 10, 2007 | 02:41 PM
330R's Avatar
Default Re: (MadSuRfEr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadSuRfEr &raquo;</TD></TR><TR><TD CLASS="quote">its the input shaft bearing. i have the same noise and thats what my buddy thats an acura tech told me. </TD></TR></TABLE>
I concur. There have been other threads on this topic before and they also point to the input shaft bearing. My trans has the same issue, but it's usually pretty faint still.
91004-P21-003 BEARING, ANGULAR BALL (28X72X18)
Old Oct 10, 2007 | 08:07 PM
vtecthiss's Avatar
nah
Old Oct 10, 2007 | 08:32 PM
powersteer's Avatar
can anyone confirm that its the input shalf bearing? i have the same noise too. how to prevent it from coming back if i changes the bearing?
Old Oct 10, 2007 | 11:48 PM
floatfisher's Avatar
i have the same noise...ill be changing my bearings whenever the clutch takes a dump
Old Oct 11, 2007 | 01:06 AM
ITR184's Avatar
Default Re: (The Kernel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Kernel &raquo;</TD></TR><TR><TD CLASS="quote">
Is this something that needs attention or can I let it go unless it starts to sound worse? </TD></TR></TABLE> With 34k I would think you be okay for a while. If you still have the stock clutch, I would wait until you need to replace the clutch. If mine starts making noises under a load I will be a little more concerned.
Aquafina's Avatar
With the clutch out it could be the ISB or TOB.
ISB is more of a whirring knock, TOB is a whine.
If its the ISB, replace ASAP or you'll be needing a new trans after it explodes.
Old Oct 11, 2007 | 05:37 AM
I'll try and take some audio of it. I think its loud enough to tell and hear online via high quality. I do that tonight after work.
Old Oct 11, 2007 | 05:45 AM
GO-FIGHT-KILL's Avatar
I had this same noise in my transmission, before it blew (Not related to the noise).
The input shaft bearing, main bearing, and differential bearings, were replaced. My mechanic who rebuilt it (Same Acura Technitian as Madsurfer refered to), told me the input shaft bearing was the cause of the noise.
After it went back it, idle was quiet as could be.
Old Oct 11, 2007 | 06:28 AM
So It def sounds like a bearing problem. How long do I have before something bad can happen?
Old Oct 11, 2007 | 06:29 AM
Ed 341's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">So It def sounds like a bearing problem. How long do I have before something bad can happen?</TD></TR></TABLE>
I got to 135,000 without anything bad happening. I pushed the envelope.
Old Oct 11, 2007 | 08:07 AM
Larkin W.'s Avatar
Default Re: (330R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 330R &raquo;</TD></TR><TR><TD CLASS="quote">
91004-P21-003 BEARING, ANGULAR BALL (28X72X18) </TD></TR></TABLE>
Yup, I just recently replaced all transmission bearings, put in a new clutch, flyweel, and rear main seal. Tranny is quite as can be.
My gears looked great for having 104,000 miles on them. Didn't replace any syncros or gears because it does not grind and wear looked normal
Old Oct 11, 2007 | 09:39 AM
Aquafina's Avatar
I toasted my ISB during the last session at Expo 5. Made it 999 miles back home and a couple hundred after that until my new clutch/fw/etc came in along with the new ISB and seal.
Old Oct 11, 2007 | 09:46 AM
Gorman's Avatar
Are these gearbox bearings expensive??
Old Oct 11, 2007 | 09:48 AM
Aquafina's Avatar
Default Re: (Gorman)
ISB is about $25. At least for my D. Probably similar for the B.
