D16 Radiator on a GSR
I am putting a GSR into my 95 civic and i want to know if the radiator from a d16 (which was originaly in the car) will work to keep that motor cool enough or will i have to get a different one?
Yea you should be fine, I am useing my stock radiator (92 civic cx) on my Jdm b18c type r swap, and it stays perfect. I have even heard of people useing stock radiators with h22 swaps with out any problems. It also might depend on where you live.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Panda Eg6 »</TD></TR><TR><TD CLASS="quote">Yea you should be fine, I am useing my stock radiator (92 civic cx) on my Jdm b18c type r swap, and it stays perfect. I have even heard of people useing stock radiators with h22 swaps with out any problems. It also might depend on where you live.</TD></TR></TABLE>
CX radiator is half-size single core, no? If you're ok in WA, I would say the other guy would be fine in WI as well. I run my stock half-size dual core (EX) radiator with my GSR swap and it's fine. NJ gets a little hot sometimes and I've had no issues
an idea just to be safe, u can always change out ur thermostat to a 172 degree ... i dunno..thats what i did and im running a stock dx radiator with a jdm gsr .. it keeps it nice an cool
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk00EJ8 »</TD></TR><TR><TD CLASS="quote">
CX radiator is half-size single core, no? If you're ok in WA, I would say the other guy would be fine in WI as well. I run my stock half-size dual core (EX) radiator with my GSR swap and it's fine. NJ gets a little hot sometimes and I've had no issues </TD></TR></TABLE>
Yep yep
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jus_spooln_wicha »</TD></TR><TR><TD CLASS="quote">an idea just to be safe, u can always change out ur thermostat to a 172 degree ... i dunno..thats what i did and im running a stock dx radiator with a jdm gsr .. it keeps it nice an cool</TD></TR></TABLE>
Yea that would be a good idea to
Yep yep
You will be fine. When I had my B18c in my EJ I was still using the stock radiator. Like others have said, you can get a lower temp thermo or even find a cheaper aftermarket radiator with a larger core/tank. I know RCautoworks has some 1/2 size EG/EK radiators that they use on their DOHC-T motor and it works just fine
yeah u will be fine..i am running b16a sir 2 with d series radiator in my eg hatch..runs fine.
but the problem is b series ratiator hoese are bigger than d series..so u have to use water hose clamp to tight on the radiator .i mean real tight
WhiteOnRice
13
Oct 28, 2007 06:57 PM
racekar
Aug 17, 2004 11:46 AM
