most power ever seen made on 60-1/t4?
Old Oct 9, 2007 | 11:28 PM
DLB1994's Avatar
Default most power ever seen made on 60-1/t4?
whats the most power have anyone seen a t04s/60-1 p-trim .69 oncenter t4 turbine make ?
on a B series engine
Old Oct 10, 2007 | 09:32 AM
b18bturbo's Avatar
Default Re: most power ever seen made on 60-1/t4? (DLB1994)
most i could muster up was 640 28psi limit on that couldnt get any more out of it.
Old Oct 10, 2007 | 05:10 PM
DLB1994's Avatar
Default Re: most power ever seen made on 60-1/t4? (b18bturbo)
not bad, whats the engine setup?, my goal is to make 600whp and break the 9sec mark with my ek, and i all ready have that turbo so i guess im going to use it
Old Oct 10, 2007 | 07:07 PM
dcCale's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">most i could muster up was 640 28psi limit on that couldnt get any more out of it. </TD></TR></TABLE> what setup are you running im looking for similar numbers
Old Oct 10, 2007 | 09:20 PM
GA-AutoFab's Avatar
Default Re: most power ever seen made on 60-1/t4? (dcCale)
i'd reccomend a tangential housing and .81 or larger. running divided with a correct manifold will help with lag and you can get away with a even larger housing. on center housings don't flow well.
Old Oct 10, 2007 | 09:40 PM
SwappedTURBOegg's Avatar
might need abit more power for nines
Old Oct 10, 2007 | 10:57 PM
DLB1994's Avatar
Default Re: (SwappedTURBOegg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwappedTURBOegg &raquo;</TD></TR><TR><TD CLASS="quote">might need abit more power for nines </TD></TR></TABLE>
i have seen a few eg and ek's break 9.9's and 9.80's with 600-650whp
same as we have put eg and ek's in the 10.9-10.8's range with only 390-440whp
Old Oct 10, 2007 | 11:00 PM
DLB1994's Avatar
Default Re: most power ever seen made on 60-1/t4? (GA-AutoFab)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GA-AutoFab &raquo;</TD></TR><TR><TD CLASS="quote">i'd reccomend a tangential housing and .81 or larger. running divided with a correct manifold will help with lag and you can get away with a even larger housing. on center housings don't flow well.</TD></TR></TABLE>
yeh i understand that , only why i said that turbo cause i have it laying around if i was to buy a new turbo i wouldnt think of the 60-1 with my goals !!
Old Oct 11, 2007 | 05:32 AM
b18bturbo's Avatar
it was the first turbo i ever used on the drag car back when e htought 60-1 were big for 4cyl go figure..
60-1 .68ar t4 unit b18c 81mm setup
Old Oct 11, 2007 | 06:47 AM
.CUBISH.'s Avatar
if you have to ask how much power a 60-1 makes i highly doubt you will have much luck getting into the 9's with 600hp..its not easy
Old Oct 11, 2007 | 07:23 AM
B18c1turboedEK's Avatar
Default Re: most power ever seen made on 60-1/t4? (.CUBISH.)
I did 660 at 28 psi last year on it.. It was with a stock bore motor, 9:1 compression pistons.. hope that helps
DOHC Kid
May 16, 2008 09:55 AM
builtturboeg
Mar 5, 2008 06:15 PM
dumas07
Jul 17, 2006 05:18 PM
B18CXr
Jul 21, 2005 01:34 PM
88crxvtec
Jul 10, 2003 06:50 PM
