most power ever seen made on 60-1/t4?
whats the most power have anyone seen a t04s/60-1 p-trim .69 oncenter t4 turbine make ?
on a B series engine
Re: most power ever seen made on 60-1/t4? (b18bturbo)
not bad, whats the engine setup?, my goal is to make 600whp and break the 9sec mark with my ek, and i all ready have that turbo so i guess im going to use it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">most i could muster up was 640 28psi limit on that couldnt get any more out of it. </TD></TR></TABLE> what setup are you running im looking for similar numbers
Re: most power ever seen made on 60-1/t4? (dcCale)
i'd reccomend a tangential housing and .81 or larger. running divided with a correct manifold will help with lag and you can get away with a even larger housing. on center housings don't flow well.
Re: (SwappedTURBOegg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwappedTURBOegg »</TD></TR><TR><TD CLASS="quote">might need abit more power for nines </TD></TR></TABLE>
i have seen a few eg and ek's break 9.9's and 9.80's with 600-650whp
same as we have put eg and ek's in the 10.9-10.8's range with only 390-440whp
Re: most power ever seen made on 60-1/t4? (GA-AutoFab)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GA-AutoFab »</TD></TR><TR><TD CLASS="quote">i'd reccomend a tangential housing and .81 or larger. running divided with a correct manifold will help with lag and you can get away with a even larger housing. on center housings don't flow well.</TD></TR></TABLE>
yeh i understand that , only why i said that turbo cause i have it laying around if i was to buy a new turbo i wouldnt think of the 60-1 with my goals !!
it was the first turbo i ever used on the drag car back when e htought 60-1 were big for 4cyl go figure..
60-1 .68ar t4 unit b18c 81mm setup
if you have to ask how much power a 60-1 makes i highly doubt you will have much luck getting into the 9's with 600hp..its not easy
