Question about putting H22 in fifth gen accord!
Old Jun 19, 2002 | 07:03 PM
93eg-EKhybrid's Avatar
Default Question about putting H22 in fifth gen accord!
I was just wondering if I would be able to use the stock Prelude harness instead of messing with the Accord harness. Plus, if I buy a 94 or 95 Accord, will there be a problem using a 96 Prelude motor and wiring harness? Thanks for the help guys.
Old Jun 20, 2002 | 07:00 AM
jeff652's Avatar
Default Re: Question about putting H22 in fifth gen accord! (h22ybridAccord)
thee plugs on the firewall don't match. you have to re-use the accord harness and extend/modify a few wires.
I know I've done this swap . . .
Old Jun 20, 2002 | 07:27 AM
Default Re: Question about putting H22 in fifth gen accord! (jeff652)
Now why can't you just replace the entire wiring harness with the prelude one? Plugs and all. Or is there an issue with the guages wiring and other stuff like that? Does the Prelude ECU plug into the Accord wiring harness? Also, where would a good website be, to go and find info on what wiring I need to change and stuff like that be? Thanks.
Old Jun 20, 2002 | 03:03 PM
KTeller8's Avatar
h22a.com
and yeah you need to change the wires. and keep the accord harnes.. you can use the prelude ecu.
KTeller8's Avatar
oh yeah.. if you use a 96 lude.. dont use its ecu .. cause the 96 is obd2 and it will mess things up.
Old Jun 21, 2002 | 12:54 AM
Default Re: Question about putting H22 in fifth gen accord! (KTeller8)
So then I should buy an OBD1 P13 ECU then?
Old Jun 21, 2002 | 03:56 PM
hondaeg5's Avatar
i just finished putting a h22 in my friends 93 accord. it wasnt easy! we used the accord harness with a few mods. this swap is a challenge but a fun one. <U></U>
bmw tech by day
honda tech by night
Old Jun 21, 2002 | 06:30 PM
Default Re: Question about putting H22 in fifth gen accord! (hondaeg5)
Where can I go to get a description of the modifications to the wiring harness I have to do?
Old Jun 24, 2002 | 03:48 PM
hondaeg5's Avatar
no mods really. just have to add vtec and knock sensor. buy a helms for both cars,it will be your bible!!
accord ricer
Oct 28, 2012 03:41 AM
spurge
Dec 18, 2006 05:53 PM
DrkGreenAccord
Oct 21, 2002 12:40 PM
Angel29
Oct 15, 2002 06:25 PM
