90 Hatch w/ z6 boosted swap will not run
ok i got a 90 civic hatch at the house for over a year now and i want to get this thing started... (d16z6 sohc vtec turbo)
i was going to swap it so i took all the sensors n crap out, but last min decided not to.
someone stole my hood so it sat for a few weeks wit no hood in chicago weather.
i a few weeks ago i connected everything back together and now i get nothing. not a sound when i try to start the car.
i tried jumping it= it made one crank noise. now nothing
what could it be,
rusted camshafts?
need new starter?
alternator?
any suggestions
also the last day i drove it, i did an oil change, drove it around the city and all of a sudden it stopped boosting... what could cause this also.
on my boost- vac gauge it would go from -x(vac) to 0 but never go to the boost side. i could hear the turbo but no BOV?
any help would be appreciated thanks
Modified by SF_Dee at 1:15 AM 10/11/2007
what could it be,
rusted camshafts?
need new starter?
alternator?
any suggestions
idk about driving it in the city...but for the first part where u said u dont get anything...check if u connected the wire from the harness to the started..had same problem..
if you didnt get any crank until you jumped it try getting a new battery...
and about your boost issue....sounds like you just popped a charge pipe off or something??
Boost problem would either be a worn coupling that's leaking, popped off charge pipe or a blown turbo (spins but won't boost).
Make sure your starter is getting starter signal from your key. If the battery is worn, or if the starter is dead, you should at least here the solenoid click.
You leaving it outside in the weather with no hood is the main problem.
Check your couplers see if any of them are disconnected/not tight that would cause the boost problem.
aii im prob gonna reground everything once i can find a wire diagram for mah car...anyone know what guage and what kinda wire should i ground everytihng with....
if interested i live in chicago i can check it out. im a senior tech for roto lm mazda subaru but i drive and live honda's. also deal with and built many, worked for spl auto tunning let me know if you want to throw me a some cash that would be cool too.
OK... finaly some progess.
fixed all the ghetto grounds =good
changed the starter =crank
got no spark
changed all sparkplugs cleaned cap =spark
the altornator was fucked up so the belt just smoked
changed the altornator =good
put a gallon of some new gas=dunno yet...
BUT STILL WONT STAY ON
it would crank and nothing
it would crank turn over then nothing...
what could it be now... thanks
got no spark
dam dude that sucks i jus bought a 91 civic hatch an it dont have a motor you think you could give me some ideas thats you would think would made my car a lil cleaner?? An i have a LS motor on tha way what all do i need to do to get this thing boosted?
rocker_boy_22
Jul 4, 2012 01:51 PM
90hatch94dsm
Feb 5, 2005 11:01 AM
