battery light on all the time?
Old Oct 9, 2007 | 09:46 PM
wbaldwin_86's Avatar
Default battery light on all the time?
hello,
i have looked through countless threads, but i could not find an answer. when i try to start my car, 1998 civic with a lsvtec, it will not crank over. the battery light stays on all the time when it is in ignition 2. i have ran a obd2 scanner and it just says failed. i am running and 2000si engine harness with a p2t ecu. i have also had the battery starter and alternator tested and they all came up great.
thanks a lot
bill!
Old Oct 9, 2007 | 09:47 PM
Hardedge's Avatar
Default Re: battery light on all the time? (wbaldwin_86)
Maybe you could replace the battery?
Old Oct 9, 2007 | 09:49 PM
Default Re: battery light on all the time? (Hardedge)
i have had the battery tested, and used my battery from my other car
but thanks for the input
bill
Old Oct 9, 2007 | 09:52 PM
Hardedge's Avatar
Wow, I wish I could help more people on here but I just don't really know anything about swaps, and that seems to be what everyone does. Honda put a great engine in my car for me!
Old Oct 9, 2007 | 10:01 PM
USDMCIVICHATCH's Avatar
how are you using a 99-00 harness on a 96-98? did you change the dash harness?
Old Oct 9, 2007 | 10:12 PM
Default Re: battery light on all the time? (USDMCIVICHATCH)
yeah i bought the car from a insurance company as a theft recovery, and i had to get a new car wiring harness...
Old Oct 9, 2007 | 11:26 PM
a good night bump!
Old Oct 9, 2007 | 11:36 PM
Panda0000's Avatar
damn .... i cant help you either ... but if u cant find answer bring it to a shop let them find the problem and take it home and fix it . always work for me and dont spend to much money .
Old Oct 9, 2007 | 11:43 PM
Default Re: battery light on all the time? (Panda0000)
thanks for the input, but i have never taken a car to any shop. if a shop can figure it out, i can too.
Old Oct 10, 2007 | 08:35 AM
bump?
Old Oct 10, 2007 | 08:43 AM
Archidictus's Avatar
Unceasing Measure
If the OBD scanner comes back with a "failed" result, that suggests you wired something up incorrectly. It only takes one misplaced wire to screw up a lot of things.
If you're confident in your wiring abilities, it might be a problem with the gauge cluster, but with the scanner issue I wouldn't bet on it.
Old Oct 10, 2007 | 08:48 AM
Default Re: battery light on all the time? (Archidictus)
it was working... it was reading a po113... now after i fixed that it just says failed.
thanks
Old Oct 10, 2007 | 01:22 PM
good afternoon bump!
Old Oct 10, 2007 | 03:38 PM
spoon_ek9's Avatar
when does yr car not crank over got to do with yr charging light? it will be on anyway when yr engine is not running.
Old Oct 10, 2007 | 03:46 PM
Default Re: battery light on all the time? (spoon_ek9)
oh wow i need to be more observative... thanks for the input. now i just need to find out why my car isnt cranking over
Old Oct 10, 2007 | 09:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wbaldwin_86 &raquo;</TD></TR><TR><TD CLASS="quote">hello,
thanks a lot
bill!</TD></TR></TABLE>
what do you meen it will not crank over? does it spin and just not start or does it just click and nothing happens at all? also be a little more specific as to what you have done to the car so far
84Riceeater
Jun 30, 2015 06:56 PM
GoodUsername
Jun 1, 2015 01:47 PM
Bad_dude
Jan 25, 2011 07:10 PM
Chicago_Boosted_SI
Jan 31, 2008 09:49 AM
goliyong
Honda Civic (2001 - 2005)
Jun 20, 2007 06:31 PM
