Identifying Turbo?
Old Oct 9, 2007 | 04:09 PM
vietxdragon's Avatar
Default Identifying Turbo? PICS
Ok just recieved my turbo but i don't know the exact specs of it.
So far i've made out it has these numbesr
Serial #: JBM 121826
Part #: 466159-5004
It's a T3/T04E it looks like , and has a .60 A/R turbine housing, .63 stamped on the exhaust side of it. The turbo inlet is 3" and the outlet is 2 1/2"
what size trim is it exactly? is it a .60 trim ? i hope so thanks
Jimmy
PICS:
Modified by vietxdragon at 5:01 PM 10/11/2007
Modified by vietxdragon at 5:02 PM 10/11/2007
Old Oct 9, 2007 | 06:36 PM
Custom Rex's Avatar
Default Re: Identifying Turbo? (vietxdragon)
maybe garret 60-1? , T-1?
Old Oct 9, 2007 | 06:37 PM
well just looked it up it WOULD'VE been a 60 trim, but the ****** scribed a 4 in place of where a 3 was so i guess its really a 57 trim! damn *** wipe! lol
Old Oct 11, 2007 | 07:36 AM
ok so i took pics
Old Oct 11, 2007 | 08:02 AM
bump for posted pics
Old Oct 11, 2007 | 12:26 PM
Bailhatch's Avatar
Default Re: (vietxdragon)
measure the compressor wheel and you will know. maybe it was changed out for a 60 trim cover and wheel.
Old Oct 11, 2007 | 12:34 PM
93supercoupe's Avatar
Default Re: (Bailhatch)
i was thinking the same, i doubt anyone would go through the time to scribe a false number into it.
To be honest, it would probably be easier to sell a 57trim than a 60.
Old Oct 11, 2007 | 01:29 PM
tepid1's Avatar
Default Re: (93supercoupe)
It is a 57 trim.
Old Oct 11, 2007 | 03:23 PM
TheShodan's Avatar
Moderator
Default Re: (tepid1)
The part number seems to have changed to that of a 60 "trim" turbo. No way to tell unless seeing measurements by removing the covers.
Old Oct 12, 2007 | 08:29 AM
when measuring is the information on the garrett site , what i would go by? like measuring the inducer and exducer? this would be my first time any help would definitely be nice!
Old Oct 12, 2007 | 09:07 AM
ryan89crx's Avatar
measure it and find out
http://www.homemadeturbo.com/f...066.0
Old Oct 12, 2007 | 11:01 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietxdragon &raquo;</TD></TR><TR><TD CLASS="quote">well just looked it up it WOULD'VE been a 60 trim, but the ****** scribed a 4 in place of where a 3 was so i guess its really a 57 trim! damn *** wipe! lol</TD></TR></TABLE>
Scandalous! Did you buy it from someone on HT?!
Old Oct 12, 2007 | 11:48 AM
ebay.... lesson definitely learned
Old Oct 15, 2007 | 08:02 AM
well cracked it open , unfortunately my camera was out of battery so i couldnt take any pics. But it was a 60 trim on the compressor side, i couldnt get to the turbine wheel side. But thats interesting how the internals were swapped out? is that even possible?
Old Oct 15, 2007 | 06:07 PM
Bailhatch's Avatar
So they just swapped the compressor wheel and cover most likely. It's very easy to do but, with most turbos it needs to be balanced again as an assembly. I dont see any places where weight was removed from the nut on the compressor wheel. I'm not sure if that exclusively means it has not been balanced...just pointing it out.
I would bet its just the regular 'stg 3' turbine wheel that nearly all hybrid t3/t4s sport. measure the end you can see, if you want to be 99% sure.
Old Oct 15, 2007 | 06:31 PM
well it supposedly had 2500 miles on it, i mean i can spin the wheel freely no rub or any shaft play
Old Oct 16, 2007 | 03:41 PM
TheShodan's Avatar
Moderator
Just because you can spin it by hand doesn't mean that it might be off balance. remember, these things are spinning in essence of about 90,000 rpms when pushed.
Here's the way you tell which is which..
Old Oct 16, 2007 | 03:59 PM
how do i get it balanced? theirs a place around here called michigan turbo's but i heard nothing but bad things any place on h-t that does?
Metal Head
Oct 25, 2006 06:30 PM
TURBO DC2
Mar 28, 2005 07:25 PM
yimmy
Mar 13, 2003 05:12 PM
metal-x
Nov 26, 2002 01:01 PM
Jared
Nov 19, 2001 05:38 AM
