Dumptube bracing ideas - keeps cracking
First time around this think cracked at the Vband flange. I added the two braces. 200 miles later the braces cracked at the weld. Any other ingenuitive ideas out there on how to support this thing?
............none should be needed for that........ the thermal expansion of the metal will just keep cracking them
if its made right and with the right materials you dont need any
Thermal expansion was the reason I didn't use the braces to begin with, then it cracked at the top of the V-band flange. I admit, that is a rather long moment arm for that much mass (Tial 44). How thick of a tight mandrel bend like that can be easily found in 1.75"?
if you welded tabs on each flange and then bolted a brace in between it may help the problem, or possibly two bungs and a rod in between with spherical rod ends
just some ideas
just some ideas
you could use a 1.5" schedule 10 or 40 pipe elbow. i'd take out those two rods and make a proper gusset to run between the two flanges that follows the radius of the bend and weld it all along the pipe on both side of the gusset.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech »</TD></TR><TR><TD CLASS="quote">you could use a 1.5" schedule 10 or 40 pipe elbow. i'd take out those two rods and make a proper gusset to run between the two flanges that follows the radius of the bend and weld it all along the pipe on both side of the gusset.</TD></TR></TABLE>
a full gusset would work as well.
.. 1/8" flat sheet cut in a half moon welded all the way would probably follow this same premise
Found a .145" wall SS bend at McMaster part# 45555K515.
THis will reduce a lot of stress because it is shorter in addition to being over twice the thickness of the existing pipe.
I normally only backpurge with butt welds. I probably only got 90-95% penetration on that pipe. Probably not the strongest method, but it's not easy welding 7/16" plate to .065" pipe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Will braces or brackets make a dumptube crack faster since it will prohibit thermal expansion?</TD></TR></TABLE>
well it depends, on longer parts you may experience that, on shorter pieces its not such of an issue, and being like metals it should expand slightly but at the same rate throughout (if its longer the areas getting more heat closer to the turbo will expand more and areas further away will expand less)
hootiehoo
Welding / Fabrication
Sep 8, 2010 06:15 AM
covertperformance
Mar 25, 2009 05:56 PM
