does anyone have the diagram for the three main plug ins (gray, blue, green)?
Old Jun 19, 2002 | 05:41 PM
infamousALLMTR's Avatar
Default does anyone have the diagram for the three main plug ins (gray, blue, green)?
coming off the fuse box... I am putting an integra dash in my vehicle (92 civic vx) and need to change the pins so the integra main harness will clip right in with the stock civic female connectors (off the fuse box). I have seen these diagrams before but cant find them and did not save them.. please help
[Modified by infamousRRH, 6:45 PM 6/19/2002]
Old Jun 19, 2002 | 06:04 PM
Default Re: does anyone have the diagram for the three main plug ins (gray, blue, green)? (infamousRRH)
dont try the "try the search button" routine because I did and all I found was "hey dude, try searching"
Old Jun 19, 2002 | 06:11 PM
DragII's Avatar
25 Year Member
Default Re: does anyone have the diagram for the three main plug ins (infamousRRH)
I was not aware that helms went out of buisness
Old Jun 19, 2002 | 06:13 PM
Default Re: does anyone have the diagram for the three main plug ins (DragII...Enfuego!!!)
putting dash in right now and have a integra helms just not a civic one.
Old Jun 19, 2002 | 06:21 PM
DragII's Avatar
25 Year Member
IC, well...I don't have a diagram to post, but if you can get more specific in which wires you need to know...I can help.
Old Jun 19, 2002 | 08:47 PM
dont be shy
Old Jun 19, 2002 | 08:58 PM
migs's Avatar
What year harness are you using? If you are running OBD2 harness, say good night and find an OBD1.
Old Jun 19, 2002 | 09:16 PM
TurboBumblBee's Avatar
Default Re: does anyone have the diagram for the three main plug ins (MiGs)
whats up migs? btw, migs knows his sheit.. he has done it.. why an obd1 harness just wondering cause i would like to do it to my coupe also one day?? i can talk to me more and get more details but is it cause the obd2 harness is those smaller fuses and obd1 is the larger ones?
Old Jun 19, 2002 | 09:26 PM
migs's Avatar
Default Re: does anyone have the diagram for the three main plug ins (95CivicEX)
The OBD2 harness measured RPM's through the ECU. It had no true live RPM wire. The OBD1 harness ran a wire by itself (not running to the ECU). A friend of mine had helped me find that information out.
Also, what year cluster are you using? If 99+ (start year of the immobilizer), your turn signals will not work properly, even if you nail all the conversions. Get a hold of a pre-98.
If you have an OBD1 harness, alot of the connections can be done as trial an error.
I had all my diagrams and conversions, I could have made it easy for toy but my EG was stolen so I tossed just about everything that was related to the car.
Old Jun 20, 2002 | 03:16 PM
what type of immobilizer are you talkin about? or what is it? isnt that just part of the factory alarm or what?? and why cant your make it work in the civic?
*edit* is that the thing is the key in newer cars? i wish i had one of them in my civic..
[Modified by 95CivicEX, 12:57 AM 6/21/2002]
jdmcuban
May 29, 2006 05:11 PM
rxse7n
Mar 18, 2004 10:50 PM
