reverse lights
Old Oct 8, 2007 | 04:31 PM
viciousef9's Avatar
Default reverse lights
A friend of mine told me the other day that when i go in reverse that my reverse lights dont come on anymore. i check the bulbs and they are fine. i know a little about the reverse switch on the tranny. but not enough to fix it. could any help me out with what i need to check? if possible please provide pics. and i did search already.
Old Oct 8, 2007 | 04:36 PM
Duane_in_Japan's Avatar
Default Re: reverse lights (viciousef9)
You need a volt meter to see if the PRNDL switch is giving power at R setting, maybe a bad ground back at the lights.
Old Oct 9, 2007 | 06:02 PM
~sp33~'s Avatar
EFB055
My reverse lights stopped working ages ago. Its a PITA trying to reverse into a busy street.
Old Oct 9, 2007 | 06:29 PM
viciousef9's Avatar
i know what you mean. people dont know what you are doin so they panic.
Old Oct 9, 2007 | 07:29 PM
Max Kling's Avatar
Im not sure if the switch is controlled by ground or power its been a while. But check with a voltmeter if your getting power with the ignition on, on one of the two bullet connector. Im almost 100% sure is a power switch someone might be able to shead some light.
Old Oct 9, 2007 | 09:05 PM
Default Re: (Max Kling)
I had to rewire an old 80s Accord with no backup lights, the center console shifter PRNDL switch gave power but none went back to the light sockets, so I just spliced into the PRNDL harness and ran a whole wire back to the trunk and spliced into the proper wire back there and called it good for the Japanese safety inspection.
Old Oct 10, 2007 | 03:41 PM
viciousef9's Avatar
i dont have an automatic. so i dont even want to hink about where to start with the splicing wires. thank for the suggestion though.
Old Oct 10, 2007 | 10:30 PM
Default Re: (viciousef9)
Then your reverse switch is on the transmission, start a new thread, this one is too old to get someone to give you a maintenance diagram from a repair manual on how to test your reverse switch, I bet its bad.
justicap
Aug 8, 2016 03:28 PM
burnoutboy
Aug 28, 2013 08:31 AM
JDMJUNKIEMONKIE
Oct 25, 2009 02:17 AM
ttk3
Lighting
Jan 14, 2008 04:34 AM
SL!M
Mar 7, 2003 09:43 PM
