Reverse lights just magically stopped working
Old Aug 24, 2013 | 01:36 PM
burnoutboy's Avatar
The Credible Hulk
Default Reverse lights just magically stopped working
Okay, I'm leaning towards a short or a bad reverse switch but wanted to get a quick brainstorm going before I tear into it.
I JUST noticed two nights ago my reverse lights aren't working. I have aftermarket tails lights with LED tail and brake lights but regular Sylvania reverse bulbs.
I have already checked fuses and connections at the bulbs and at the reverse sensor on the trans.
My next steps will be to check for continuity at the bulb socket and to try a second reverse light sensor that I have. Outside of that I'm thinking I'm gonna have to check the wiring for a short. Is there an obvious possibility that I'm missing or am I on the right track?
Old Aug 24, 2013 | 02:58 PM
jdmh22eg2's Avatar
Default Re: Reverse lights just magically stopped working
well just checkig for continuity does not tell you if you have a power source or if the lights drop out with a load applied to lights. if you have power probe start at switch on trans apply power source and see if the light up, if not work your way in direction of a power source till you do and find the issue
Old Aug 26, 2013 | 05:33 PM
fcm's Avatar
fcm
Old Fart
MM&Y of car would help, along with trim level, also auto or manual????? 94
Old Aug 27, 2013 | 11:54 AM
burnoutboy's Avatar
The Credible Hulk
It was the reverse switch. Swapped it for a spare known good one and it's money. Good to have a ton of random parts at your disposal LOL.
Thanks for the replies.
Old Aug 28, 2013 | 06:32 AM
fcm's Avatar
fcm
Old Fart
I agree, I have all sorts of random parts for my 94RS and it is 50% off at PicknPull this weekend and two "new" Integras at the yard that I have not pulled from yet, one of the things I do not have yet is a reverse light switch, among other things. 94
Old Aug 28, 2013 | 08:31 AM
burnoutboy's Avatar
The Credible Hulk
I'll send you a reverse light switch and some cash if you can find me a outer tranny case for a B series hydro!!!!! I have about 4 known good ones LOL.
StayKrafty
Feb 16, 2018 09:39 AM
shdow8948
May 19, 2011 08:53 AM
crx1racing
Jun 1, 2005 11:00 PM
cpizzy
Dec 16, 2003 02:59 PM
