90 CIVIC SI HB
Old Oct 8, 2007 | 08:25 AM
AEC_SI_04's Avatar
Default 90 CIVIC SI HB
Yes I did a DPFI to MPFI swap it is just about finished, but I have one thing left to do. I have a code 4 flashing and someone told me I need to switch 2 wires on the distributor and I don't know witch ones I switch can anyone help me. I think that is why my rev limiter is hitting at 3000 rpms.
thanks for the help
Old Oct 8, 2007 | 09:36 AM
The_Undertaker's Avatar
75.168.105.221
Blue wire is tachometer that reads out rom and the black wire is the ground inside dizzy.
Old Oct 8, 2007 | 09:38 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (The_Undertaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Undertaker &raquo;</TD></TR><TR><TD CLASS="quote">Blue wire is tachometer that reads out rom and the black wire is the ground inside dizzy. </TD></TR></TABLE>
Wow, that greatly informative answer is so helpful, I'm sure glad you're around.
OP, have you gone over your MPFI swap instructions carefully? We don't know how you wired up the dist, so it may be numerous wires. Maybe take a picture of your 7-pin connector for the dizzy and we can tell you what's what?
And yes, throwing code 4 will cause your car to go into limp mode.
Old Oct 8, 2007 | 10:09 AM
wiZCo's Avatar
Stouts 'n' Scotch
Do your wires match up as so?
Old Oct 11, 2007 | 06:13 AM
AEC_SI_04's Avatar
Default Re: (wiZCo)
There are 4 wires 2 going to c1 & c2 orange, white crank angle and 2 going to b10 & b12 cylinder sensors.
Thanks
Old Oct 11, 2007 | 06:14 AM
AEC_SI_04's Avatar
Default Re: (wiZCo)
your pic didn't show up
But Thanks
Old Oct 11, 2007 | 07:37 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (AEC_SI_04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AEC_SI_04 &raquo;</TD></TR><TR><TD CLASS="quote">your pic didn't show up
But Thanks</TD></TR></TABLE>
Don't know why it disappeared.
Here's the link I got it from: http://www.angelfire.com/d20/h....html
Old Oct 11, 2007 | 11:12 AM
jry2598's Avatar
Default Re: 90 CIVIC SI HB (AEC_SI_04)
if you have a 90 si its already muti point. why would you muti pointa si?
Old Oct 11, 2007 | 11:25 AM
SIred91's Avatar
Rainman
Default Re: 90 CIVIC SI HB (jry2598)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jry2598 &raquo;</TD></TR><TR><TD CLASS="quote">if you have a 90 si its already muti point. why would you muti pointa si? </TD></TR></TABLE>
question of the day
Old Oct 12, 2007 | 03:55 AM
AEC_SI_04's Avatar
It was a dpfi I made it an si.
Old Oct 23, 2007 | 08:04 AM
AEC_SI_04's Avatar
Default Re: (wiZCo)
The 7 wires on the dist. There only 2 wires going from the dist to the ECU and they are the orange and white crank angle sensors going to c1 and c2
thanks alot
89ED
Jun 16, 2016 11:36 AM
Markis.
Mar 21, 2006 08:18 PM
Hondaracer197791
11
Sep 26, 2005 06:44 PM
SleepnCiViC
16
Oct 30, 2004 11:38 PM
