Smoking blue on Decel only?
Old Oct 7, 2007 | 08:07 PM
HamiltonRex's Avatar
Default Smoking blue on Decel only?
Hey.. a friends car is smoking on decel only, no during accell, idle, cold etc.. Just on decel after he does a WOT pull or is just driving without letting off for awihle (highway driving).
Car runs/starts fine, does use much oil. Engine recently seen nitrous, but smoking problem was consistant before/during/after.
Whats the problem?
Old Oct 7, 2007 | 08:44 PM
1 2 NV's Avatar
Default Re: Smoking blue on Decel only? (HamiltonRex)
i thought on decel that would mean valve seals. its been a while since ive been into troubleshooting cars though. memory is fading too.
Old Oct 7, 2007 | 09:19 PM
b19coupe's Avatar
Likely valve seals. Decel/cruise is when engine vacuum is highest.
Old Oct 8, 2007 | 10:40 AM
Default Re: Smoking blue on Decel only? (b19coupe)
alright thanks, ill get him to do a leakdown.
Old Oct 8, 2007 | 06:23 PM
JDogg's Avatar
lol, a leakdown has nothing to do with valvestem seals.
Old Oct 8, 2007 | 07:42 PM
Default Re: Smoking blue on Decel only? (JDogg)
yeah i guess not.. doh.
Old Nov 15, 2007 | 04:00 PM
DonF's Avatar
" recently seen nitrous" start there, the answer will come to you.
B18C1NMotion's Avatar
i'm having the same problem. new oem valve seals coming soon
should be better for sure.
Old Nov 15, 2007 | 04:02 PM
BETNCORT's Avatar
Wow, you don't seem to bright judging by your spelling rex. How long have you had the teg?I used to have a 96 GS-R, lookin for a 4 door civic now. I don't think i've ever seen you round at all.
Old Nov 15, 2007 | 04:03 PM
night's Avatar
Default Re: Smoking blue on Decel only? (B18C1NMotion)
i believe don is referring to oil control rings.
though if it is valve seals you would see it on cold starts
Old Nov 15, 2007 | 05:31 PM
Runnerdown's Avatar
Default Re: Smoking blue on Decel only? (night)
This happens a lot, from what I have seen it is a problem with rings, out of round or damaged cylinders. Or all of the above.
mattyp1020
Jul 12, 2011 07:40 PM
CR3X
14
Feb 21, 2008 12:20 PM
BobyYoo
Mar 20, 2006 05:38 PM
turbociv
Jun 3, 2004 12:53 PM
bQQsted hybrid
May 27, 2002 08:44 PM
