which injectors are plug n play with no wires to cut on the harness
Old Oct 7, 2007 | 07:54 AM
949's Avatar
949
Default which injectors are plug n play with no wires to cut on the harness
im looking for injectors that will just plug up with the stock wiring system the car has without hacking the stock wiring harness.
i would prefer new injectors and not from other older cars. is there any makers out there that sell larger injectors that will just be reliable and plug right up?
i am more concerned with the harness that usually needs me to hack up and splice. i personally dont want to cut or splice the stock harness.
any links will be appreciated too.
Old Oct 7, 2007 | 12:08 PM
welfarepc's Avatar
what the f uck OBD are you running
Old Oct 7, 2007 | 01:19 PM
crazykamper's Avatar
^^ that and why do you need bigger injectors??? specify...
Old Oct 7, 2007 | 05:49 PM
949's Avatar
949
oh, i wasnt sure of what info is needed. sorry! my bad...
well i have obd0 i want to keep my obd0
running emanage blue. it works pretty good for what i need so i dont want to upgrade or change this.
i turbo'd out the d16. so before i get a tune i want to upgrade the injectors and fuel pump. i have the fuel pump but i am still shopping for the injectors.
i have been introducted a brand called DSM. i dont know anything about DSM injectors. not sure if they are p n p with the wiring harness or do i need to get some sort of clip. if i need some thing else i have no problem spending a few dollars for a clip just to make it easier and a cleaner install.
Old Oct 7, 2007 | 06:33 PM
The_Undertaker's Avatar
75.168.105.221
What size dsm injectors have you been introduced to? Dsm injectors are not plug and play and the resistor box must be the dsm 1g one not the honda obd0 one.
Old Oct 8, 2007 | 07:08 AM
949's Avatar
949
i dont have to go with the dsm. just what ever will work with out the hastle.
i was told about the dsm 400cc or 450cc. i dont remember exactly. he pointed to a silver box on the right corner of my engine bay and said its just plug n play since i have that silver box. which i dont know what it is thats all i can tell you. this box was small and had fins on it for cooling it looks like. i would assume its the resistor you are mentioning. its a stock part of the car, its not something that i had added in. so i hope that help out explaining it a bit more. i dont know if he was just telling me this to make a quick sale or he was honest was trying to help out.
Old Oct 8, 2007 | 07:29 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (The_Undertaker)
OP, I'm pretty sure that if you want to go up in injector size, you're going to have to do some modification whether you want to or not.
You will need the DSM resistor box if you're running those injectors.
BTW, "DSM" commonly refers to 92-95 Eclipses/Lasers/Talons, lots of people pilfer their turbo setups when making HMT kits.
Old Oct 8, 2007 | 07:35 AM
IT GUY's Avatar
Default Re: (wiZCo)
yup
DSM= diamond star motors
a collaboration between chrysler and mitsubishi around the time the eclipse was born..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 949 &raquo;</TD></TR><TR><TD CLASS="quote">
i would prefer new injectors and not from other older cars.</TD></TR></TABLE>
those DSM injectors are far from new.. btw
Old Oct 8, 2007 | 01:18 PM
949's Avatar
949
wow.
then any recommendations on any other brands? i noticed DSM injectors are pretty close in pricing to most other ones i see.
so any other brand recommendation
Old Oct 9, 2007 | 06:52 PM
949's Avatar
949
i also checked to see but i didnt see Power enterprise have anything.
GSR_hatch936
Sep 12, 2009 06:32 PM
Dealer Leaf
Jan 22, 2007 09:09 AM
gsrjay
Sep 24, 2004 02:47 PM
