Deactivating ABS ????????
Old Oct 6, 2007 | 02:04 PM
EJmugen's Avatar
Default Deactivating ABS ????????
Hello, I have a 1995 Civic Ex that is having ABS issues, I was told that I can deactivate the system by simply removing the ABS fuse, is this true and is it safe? if not what is a good route besides removing the entire system?
Old Oct 6, 2007 | 02:09 PM
stock_honda_coupe's Avatar
Default Re: Deactivating ABS ???????? (EJmugen)
I have a 95 civic EX and it don't have ABS.....
But whatever, yeah you can just remove the fuse and the ABS won't do anything at all.
Old Oct 6, 2007 | 02:29 PM
NOFX's Avatar
H-T White Ops
Default Re: Deactivating ABS ???????? (stock_honda_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe &raquo;</TD></TR><TR><TD CLASS="quote">I have a 95 civic EX and it don't have ABS.....</TD></TR></TABLE>
1995 Civic EX coupes came with and without ABS. The 1995 EX sedans all had ABS.
If the OP needs to know what fuse to pull, he can look in the FAQ for this section. There will be a link in there for fuse diagrams for all '92-'00 USDM Civics and del Sols.
Old Oct 6, 2007 | 02:38 PM
EJmugen's Avatar
will this process affect my normal brake system in any way?
Old Oct 6, 2007 | 03:06 PM
finnstang's Avatar
Default Re: (EJmugen)
Other than NOT having ABS, no it won't effect anything.
Old Oct 6, 2007 | 03:48 PM
btk1218's Avatar
Just note that when you do use the brakes with abs or without you have to pump when you break hard without or your brakes will lock, my 99 EX had them but 95 CX doesnt and everyday use is no different
Old Oct 6, 2007 | 04:24 PM
Default Re: (btk1218)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btk1218 &raquo;</TD></TR><TR><TD CLASS="quote">Just note that when you do use the brakes with abs or without you have to pump when you break hard without or your brakes will lock, my 99 EX had them but 95 CX doesnt and everyday use is no different</TD></TR></TABLE>
When you have ABS you apply steady pressure to the pedal. Without ABS you pump the pedal. I think you might have tried to say that but I'm not sure......
Old Oct 6, 2007 | 05:26 PM
EJmugen's Avatar
Default Re: (stock_honda_coupe)
I went ahead and located the fuses for the ABS, now do I remove all fuses related to the ABS or only a specific fuse?
Old Oct 6, 2007 | 05:35 PM
EJmugen's Avatar
But whatever, yeah you can just remove the fuse and the ABS won't do anything at all. </TD></TR></TABLE>
ABS was an option for our model, so yes I have disc all around
eurowned
Dec 3, 2007 03:05 PM
nurvcom..
Dec 19, 2005 09:31 PM
klovewell
May 2, 2004 11:23 AM
