ls vtec question
Old Oct 6, 2007 | 10:02 AM
allmotorkilla03's Avatar
Default ls vtec question
im currently getting a ls vtec swap from a friend i know how it runs but he had the gsr cams put it which to you think is better to run with gsr cams or b16 i heard b16 cams are alot better also im going to get the head ported n polished in nov.
but my main question is which is better running on a b16 head gsr cams or b16 cams?
Old Oct 6, 2007 | 10:54 AM
mmuller's Avatar
Mad Scientist
Default Re: ls vtec question (allmotorkilla03)
both pretty much the same, but if anything. gsr is betta
Old Oct 6, 2007 | 11:28 AM
i always heard b16 better but maybe im wrong bump,
Old Oct 6, 2007 | 06:39 PM
mmuller's Avatar
Mad Scientist
Default Re: (allmotorkilla03)
wrong
Old Oct 6, 2007 | 07:08 PM
posHonda's Avatar
gsr cams are a bit more aggressive but nothing substantial.
Old Oct 6, 2007 | 07:12 PM
ooo ok my fault everyone
Old Oct 6, 2007 | 07:14 PM
lunatics209's Avatar
gsr
or go with some itr's. they are really good on ls-vtec setups.
Old Oct 6, 2007 | 07:31 PM
would i have to use 93 octane gas if i used itr cams
would i have to use 93 octane if i ran with itr cams
**sorry for the double post i didnt see that i posted it once**
Old Oct 6, 2007 | 08:15 PM
silverEG6's Avatar
you prolly have to use 93 depending on your compressio ratio
Old Oct 7, 2007 | 12:00 PM
well my friend ran LS with itr piston and itr cams. he still ran 91.
Old Oct 7, 2007 | 04:50 PM
Default Re: (lunatics209)
i wanna do what ever is safe im not sure if thats good for ur shitt tho
Old Oct 7, 2007 | 07:33 PM
posHonda's Avatar
Cams shouldnt affect what kind of gas you pump but compression ratio will. Youre going to see much more of a gain if you bump up the compression ratio along with getting more aggressive cams.
Old Oct 8, 2007 | 05:25 AM
mmuller's Avatar
Mad Scientist
Default Re: (iVteC_PoWeR)
oh cams do have ann effect on compression and octane requirements..
but if anything with all things equal a bigger cam on same motor will require less octane
Old Oct 8, 2007 | 08:29 AM
gibsanez's Avatar
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">oh cams do have ann effect on compression and octane requirements..
but if anything with all things equal a bigger cam on same motor will require less octane</TD></TR></TABLE>
Static VS dynamic
Old Oct 8, 2007 | 10:27 AM
he also tuned it like that too. no problem. after that he had skunk2 stage 2 with no problems. my motor i'm running is ls-vtec with b16 head. i also ran the itr cams i bought from him and no problem here with 91.
Tong.Y
Apr 8, 2010 04:59 PM
kshgl87
Jul 24, 2007 12:57 PM
dohdoh420
Feb 13, 2007 11:30 AM
Tuahe556c
Apr 18, 2006 10:00 AM
