obd1 swap to obd2 whats needed
Old Oct 6, 2007 | 08:01 AM
dcCale's Avatar
Default obd1 swap to obd2 whats needed
hey i have a 2001 gsr and am swaping in a obd1 jdm b18c into it what do i need to do this? i think the obd2 dizzy and intake mani?
Old Oct 6, 2007 | 09:55 AM
1.8L_allmotormilitia's Avatar
you just need obd1 engine harness, obd2b to obd1 ecu jumper, and obd1 ecu.
the obd1 engine harness will plug right up into the obd2b.
Old Oct 6, 2007 | 10:04 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: obd1 swap to obd2 whats needed (dcCale)
I think the OP want to keep his car OBDIIb. That is why he asked about the OBDII distributor.
The OP will need a USDM VTEC solenoid for the VTEC pressure switch.
Old Oct 6, 2007 | 10:08 AM
alright in that case. distributor, crank sensor which is located on/near the oil pump, fuel injectors.
All i can think of from top of my head.
Old Oct 6, 2007 | 06:21 PM
dcCale's Avatar
yeah i want to keep the car obd2 and put the obd1 motor in it. so crank sensor as well as the usdm vtec solenoid pressure switch. and where is that located
Old Oct 6, 2007 | 06:48 PM
Default Re: (dcCale)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcCale &raquo;</TD></TR><TR><TD CLASS="quote">yeah i want to keep the car obd2 and put the obd1 motor in it. so crank sensor as well as the usdm vtec solenoid pressure switch. and where is that located</TD></TR></TABLE>
green plug by the vtec solenoid.
sumoneEK
25
Nov 2, 2010 07:55 AM
shiux
Aug 2, 2009 05:48 AM
Contender25
Aug 16, 2007 07:14 PM
BlkSIvic
Sep 1, 2004 10:12 AM
1man
Jul 21, 2003 11:45 AM
