Head Gasket changed now no more VTEC
Old Oct 4, 2007 | 09:42 PM
eg6madness's Avatar
Default Head Gasket changed now no more VTEC
I got my head gasket changed last week, the mechanic got the milled a little as well. I got th car back and now i have no VTEC. since i have the Hondata S300 i tried different VTEC points and still nothing. the car never switches over.
Why would this happen?
Old Oct 4, 2007 | 09:49 PM
chippy's Avatar
Default Re: Head Gasket changed now no more VTEC (eg6madness)
vtec solenoid not plugged in?
Old Oct 4, 2007 | 09:55 PM
carbonkid's Avatar
Default Re: Head Gasket changed now no more VTEC (chippy)
yea deff check to see if it is pluged in and that the plug is not broken
Old Oct 4, 2007 | 10:08 PM
gezzuzz's Avatar
they used a non vtec gasket your are fucked..
Old Oct 5, 2007 | 12:28 AM
built562's Avatar
Default Re: (gezzuzz)
check your radiator and see if there is oil in it. it will look like choclate milk.
they may have used a wrong head gasket of intalled the correct one backward.
Old Oct 5, 2007 | 12:33 AM
preludedriva's Avatar
Default Re: (built562)
mighta put it on upside down
Old Oct 5, 2007 | 02:46 AM
pdiggitydogg's Avatar
if the gasket was on upside-down he'd be leaking oil between the head/block
Old Oct 5, 2007 | 02:50 AM
eg6madness's Avatar
Default Re: (pdiggitydogg)
yeh there is no oil between the head and the block, the VTEC solenoid seem to be plugged in . and there is no oil in the radiator.
how ever they did put on the head gasket wrong the first time, and they had to start over. Oil was leaking from between the head and block then.
mijos
Sep 5, 2020 05:56 PM
Chpwhtek
Dec 14, 2011 12:31 PM
titan101
Sep 23, 2011 03:48 PM
civickid08
Dec 21, 2008 04:50 PM
