b20 b16axels
b20 b16axels
just recieved my b20 today and my buddy has a pair of b16 axels i have never used b16axels on a b20 i know the splines should match up, are they going to be to long ?
Re: b20 b16axels (jdm91CrxSi)
nope, when it comes to bseries axles they are all the same
the only difference on the axles is that ring you see some times, can't emember what it's called, but any bseries axle works on any b series
Re: (Ron454321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron454321 »</TD></TR><TR><TD CLASS="quote">Depends on if they were designed for a half shaft or not.</TD></TR></TABLE>
true true!
true true!
Re: (Ron454321)
ALL b series have the half shaft, it just depends on if it's an inny or an outty. some have the spline that goes into that half shaft, and other have the one where the half shaft has the splines and goes into the axle.
in other words ANY of them will work, as long as the half shaft side is properly matched.
NEVER seen a honda without a half shaft, every single one of them have em, at least on b series.
