blue smoke on jsm motor!
Old Oct 4, 2007 | 09:28 PM
jaskuloski97sh's Avatar
Default blue smoke on jsm motor!
k basically only put 4000 miles on this motor since i swaped it and now ive had a friend fallow me arround for a while aftr someone told me i had been blowin blue smoke. well wat we found was every ounce in a while very rarely after getting on it a huge amount of blue smoke comes rolling out but in one substance and then no more. clear as can be? non even after 5 min. of more driving. weve seen this happen about 3 times now. any ideas why? jus fyi ive changed my oil weekly because i get it very very cheap from friends shop. unessesary but still nice to have not had oil turn black on me.lol
Old Oct 4, 2007 | 09:30 PM
dagle's Avatar
Default Re: blue smoke on jsm motor! (jaskuloski97sh)
what oil are u using? black/blue is oil iirc.
Old Oct 4, 2007 | 09:32 PM
Default Re: blue smoke on jsm motor! (dagle)
castrol synthetic blend
Old Oct 4, 2007 | 09:34 PM
oh and yes i no blue is oil. sry didnt explain my full question, why would i be burning oil on this damn motor. it looked almost spotless when i got it.
Old Oct 4, 2007 | 09:35 PM
alterdcreations's Avatar
check your pcv
Old Oct 4, 2007 | 09:40 PM
Default Re: blue smoke on jsm motor! (alterdcreations)
not meant to be rude response. why?
Old Oct 4, 2007 | 09:45 PM
because it is a constant vacume source for your crankcase. if it is bad then oil will get sucked past the valve and you will smoke.
Old Oct 4, 2007 | 10:03 PM
how could i tell if its bad?
Old Oct 5, 2007 | 04:43 AM
mattsnooz's Avatar
Pinch the hose (going to pcv valve) with vice grips (AFTER wraping where you're going to pinch with a towel to dapen the vice grip's grip). When you close the line, vacuum stops and the vacuum operated switch closes and you hear a "click". If you block line and hear no click, it was never open in the first place indicating its clogged. They are part of "regular" maintenance so if it hasn't been changed, chang it anyway.
The valves (PCV) are cheap so that would be a cheap quick replacement to try to solve your problem.
u could probably just clean them couldn't you??? (pcv valves) edit*
Old Oct 5, 2007 | 08:10 AM
Default Re: blue smoke on jsm motor! (mattsnooz)
ill give it a try and let u no. thanks
Old Oct 5, 2007 | 08:33 AM
vinuneuro's Avatar
PCV valves are cheap. Get an OEM one.
MiraiZ
Apr 2, 2013 07:51 AM
Nordy
Feb 24, 2007 07:40 PM
T25So
Sep 8, 2004 11:39 AM
turbo_civic
Feb 1, 2003 07:36 PM
redteg1
Sep 19, 2002 04:29 PM
