which welder would u recommend?
Old Oct 4, 2007 | 08:58 PM
ek four's Avatar
Default which welder would u recommend?
i ended up getting the Lincoln Electric Weld Pak 3200HD
it welds both flux and mig
thanks for the help
Modified by ek four at 5:09 PM 10/9/2007
Old Oct 4, 2007 | 11:13 PM
DSRxSALSA's Avatar
in for replies too . looking for one myself
Old Oct 4, 2007 | 11:26 PM
jonsayre's Avatar
Default Re: (DSRxSALSA)
I dont know a whole lot about welding but I wouldnt even reccomend the gasless unit. Tell us more about what you are interested in using the machine for. Maybe consider saving a few hundred more dollars and buying a slightly more capable machine. In the long run you may save money because you wont have to buy another better machine. If you start getting more and more interested in welding you that machine may just end up on a shelf. Just a few thoughts.
Old Oct 5, 2007 | 06:07 AM
DESTROYER's Avatar
I have the 3200HD from the home depot. I've had it for 4-5 years now, and it works very very well!
Old Oct 6, 2007 | 07:43 AM
jcochran's Avatar
Default Re: (ek four)
I would try and get one thats 220 instead of 110, and one that allows gas hook ups. Both of those are good brands though so if you choose one I think you'll be happy with each, just compare the specs between the two.
I got a Miller 175 and I don't remember how much it cost but I don't think it was much more than that for just the welder.
Old Oct 6, 2007 | 09:15 AM
CRX T-Si's Avatar
Default Re: (jcochran)
Marked, I want to know too. Gonna get one for Christmas and would like to kno what welder is better for like minor fabrications.
Old Oct 6, 2007 | 10:54 AM
LSEGHATCH's Avatar
Default Re: (CRX T-Si)
Do what jcochran suggested. Get a machine that can have a gas hook up. I wouldn't go with a flux core only because the welds look like *** the majority of the time. Go MIG.
Old Oct 6, 2007 | 11:10 PM
domsb16's Avatar
Default Re: (LSEGHATCH)
I would go with 220 and a gas set up for mig.. and I would have to go with lincoln just because you can always go your local weld shop and thay will always have spear parts for it... as for which model. the 3200hd is nice but for a lil more coin the sp125 or the sp175 are the ****...thay have better heat and wire speed control.. the only bad thing to buy these models you have to order them through lincoln. I own all three of these and thay all work very well!
Old Oct 7, 2007 | 10:23 AM
Top Ramen's Avatar
Default Re: (domsb16)
Go for a gas-ready model - you will be much happier, no matter what kind of welding you are going to do. If you are dead set on not spending much, get a used one. I see used Lincoln/Hobart/Clarke mig welders on Craigslist all the time with gas kits for $300 - $400.
Best of luck with your project.
Old Oct 7, 2007 | 12:16 PM
welfarepc's Avatar
you can upgrade the lincoln to gas, so get that!
dunno anything about the other
Old Oct 8, 2007 | 06:07 PM
higgunscrx's Avatar
i was looking at the 3200 aswell but at home depot here in canada it cost 649 plus tax.... and the can dollar is at par with the us
might be worth a trip to the states sometime soon.
Old Oct 8, 2007 | 06:13 PM
ShawnR's Avatar
Default Re: (higgunscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by higgunscrx &raquo;</TD></TR><TR><TD CLASS="quote">i was looking at the 3200 aswell but at home depot here in canada it cost 649 plus tax.... and the can dollar is at par with the us
might be worth a trip to the states sometime soon.</TD></TR></TABLE>
u try checking home depot.com ?
EF9_TryMe
Welding / Fabrication
Feb 20, 2012 09:28 PM
pantherballhp
Dec 13, 2010 07:28 AM
danetp
Engine Management and Tuning
Sep 3, 2009 12:50 PM
swatteamtimmah
Jun 20, 2006 04:12 AM
640K Crew
Feb 21, 2006 08:29 PM
