D15B7 stuck spark plug
Old Oct 4, 2007 | 02:40 PM
Elrusodan's Avatar
Default D15B7 stuck spark plug
I had the valve cover gasket leaking oil about a year ago, before I changed it. But I guess I didnt clean the threads enough, or didnt put enough anti-seize on the new plugs.
Now one of the plugs is stuck in there really bad. It feels like it takes maybe 70ft-lbs just to turn it.
I had a little trouble removing other 3 plugs also, but not as bad as this one. This one I turned about 1/4 of a turn, and it felt like it was stuck even more. So I just tightened it back by 1/4 turn and left it there.
Is there some easy way to get it out? Does anyone know? By "easy way" I mean something that wouldnt damage the thread or make me take the head off and to a machine shop.
PS> I just had the head taken off last month to replace the head gasket. I didnt take it to a machine shop, which I regret now, they wouldve taken care of the stuck spark plug too
Old Oct 4, 2007 | 02:43 PM
wiZCo's Avatar
Stouts 'n' Scotch
Well, sounds like it's either partially frozen or is cross-threaded. My guess would be the latter. In that case, you will have to get the hole re-threaded or get a new head.
Old Oct 4, 2007 | 02:49 PM
Elrusodan's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">My guess would be the latter. In that case, you will have to get the hole re-threaded or get a new head.</TD></TR></TABLE>
How long can I drive on an old spark plug? I am hoping to drive it for at least another year before dealing with it again (1 year = 40k miles)
Should I then just get a VTEC head, if getting a new head anyway?
Does anyone know where I can find a decent VTEC head for cheap? Around Los Angeles area?
Old Oct 4, 2007 | 02:52 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (Elrusodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elrusodan &raquo;</TD></TR><TR><TD CLASS="quote">
Does anyone know where I can find a decent VTEC head for cheap? Around Los Angeles area?</TD></TR></TABLE>
You can leave it in, maybe run some Seafoam through it to clean it up. Finding VTEC heads in LA should be like finding a beer in Milwaukee; they're a dime a dozen.
Check the Marketplace here.
Elrusodan's Avatar
Another question:
Any tips on how to clean the holes for the spark plugs? There was a little bit of oil and coolant from when I took the head off and moved it around.
I tried soaking paper towels, but it is hard to get to with a paper towel around a stuck spark plug
busta7777
Feb 9, 2011 04:01 PM
InvaderJim
Mar 8, 2009 05:42 PM
GSR_hatch936
Oct 23, 2008 09:36 AM
Dorksk8tr3
Aug 18, 2005 09:46 AM
WalkingKenshin
Feb 28, 2004 02:55 PM
