h22 and h23 head same injectors and cam gears?
Old Oct 4, 2007 | 10:02 AM
southshorehighperformance's Avatar
Default h22 and h23 head same injectors and cam gears?
i have a customer wondering if his cam gears and his injectors on his prelude h23 head will work if he does a h22 head swap will the injectors and cam gears work on both??
Old Oct 4, 2007 | 11:10 AM
flyrod's Avatar
Default Re: h22 and h23 head same injectors and cam gears? (southshorehighperformance)
no
Old Oct 4, 2007 | 02:32 PM
MLBZ521's Avatar
The Injectors from the H23 are 240cc I believe and if the H22 is OBD1 the injectors are 345cc.
Skunk2 lists different Cam Gears for the H23 and H22, so I would assume other manufacturer's do also.
Old Oct 4, 2007 | 04:35 PM
cb7tougeracer's Avatar
Default Re: h22 and h23 head same injectors and cam gears? (MLBZ521)
you have a shop and dont know this?
Old Oct 4, 2007 | 06:54 PM
mattsnooz's Avatar
Default Re: h22 and h23 head same injectors and cam gears? (cb7tougeracer)
heheh!
Old Oct 4, 2007 | 09:34 PM
fabe85's Avatar
ok coming from an educated h22 owner.
92-96 h22 are 345ccs
97-01 h22 are 290ccs
all h23 are 240cc's i think
your car WILL RUN LEAN WITH h23 injectors.
Don't go to red line please i beg you!!
it will pull hard but when you pull your plugs you'll **** ur pants
Old Oct 5, 2007 | 09:15 AM
yes we are a shop but we are just getting into selling honda and acura parts we usaually deal with chevy and ford so we wanted to make sure we have the right answers for the customer thanks though
Old Oct 5, 2007 | 10:43 AM
mgags7's Avatar
The cam gears are also not compatible.
H22 = 42 teeth
H23 = 40 teeth
Old Oct 5, 2007 | 11:07 AM
Hawkze_2.3's Avatar
Default Re: (mgags7)
Also, H23 gears are the same as B-series gears (except the 3rd gen Prelude B-series).
Old Oct 6, 2007 | 07:32 AM
InvaderTrax's Avatar
Default Re: (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Also, H23 gears are the same as B-series gears (except the 3rd gen Prelude B-series).</TD></TR></TABLE>
Beat me to it
Sam1am26
Nov 30, 2012 08:09 AM
mondiex
May 28, 2012 09:55 PM
yohan
Sep 27, 2004 08:33 PM
-TJ
Jan 16, 2002 02:35 PM
