hssa internal coil distributor
Old Oct 3, 2007 | 06:46 PM
accordlxr's Avatar
Default hssa internal coil distributor
need to convert wiring in 96 lude to jdm h22a internal coil distributor obd1 where do the wires for the old crank sensor go?
Old Oct 3, 2007 | 06:50 PM
mgags7's Avatar
don't convert it like that
swap out the oil pump and distributor for obd2 units.
Old Oct 3, 2007 | 06:55 PM
accordlxr's Avatar
Default Re: (mgags7)
can't, when timing belts broke it ruined the crank sensors and the crank shaft pully is bad. So by the time i replace these and buy a new oil pump the cost would be very high. If I can use the jdm dizzy with internal coil and extend the wiring from the old sensors to the dizzy I'm hoping to do the same thing if possible.
Old Oct 3, 2007 | 06:58 PM
mgags7's Avatar
Don't do that, you'll have problems. I did, and had problems.
Old Oct 3, 2007 | 06:59 PM
accordlxr's Avatar
what kind of problems
Old Oct 3, 2007 | 07:03 PM
mgags7's Avatar
I think I'm on my 8th burnt up distributor now, and still have a "random misfire" check engine light that won't go away.
I'm in the process of buying all of the obd2 stuff now to convert it back to get rid of the problems....
Old Oct 3, 2007 | 07:06 PM
accordlxr's Avatar
i guess i will start looking for crank sensors and pully
Angeljavier3577
Apr 30, 2018 01:41 PM
hondaaccordf23
Nov 18, 2012 08:56 PM
hondaaccordf23
Nov 9, 2012 12:17 PM
BowtieHonda
Mar 19, 2012 08:15 PM
ED8DX
Nov 4, 2006 06:50 AM
